[petsc-dev] DMDA VTK viewer regression: field names missing
Matthew Knepley
knepley at gmail.com
Thu Apr 4 11:41:58 CDT 2019
On Thu, Apr 4, 2019 at 11:52 AM Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> > On Thu, Apr 4, 2019 at 12:26 AM Jed Brown via petsc-dev <
> > petsc-dev at mcs.anl.gov> wrote:
> >> Patrick Sanan via petsc-dev <petsc-dev at mcs.anl.gov> writes:
> >> > I was going to say something similar to Matt; to me it is worth the
> 1.5x
> >> > redundancy in the data if I can just view the output file with "doing
> >> > anything special". I have also done something similar to what you're
> >> > describing with save states, and it works fine; weirdly it seems like
> >> much
> >> > higher overhead than it is, though.
> >> That overhead for 2D fields isn't a big deal for me, but how would you
> >> identify that three components should be interpreted as vectors? What
> >> if they are three chemical concentrations? Plotting as vectors would
> >> just be confusing in that case.
> > In PyLith, we annotate solution fields with transformation properties
> like
> > this.
> How do you "annotate" in a VTK file?
My intention was to have them annotated in the library, and then we only
generate
VTK vectors for true vectors. For other fields we make a bunch of scalars.
Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190404/8a97ebba/attachment.html>
