[petsc-dev] Elemental & 64-bit int
Balay, Satish balay at mcs.anl.gov
Mon Apr 1 20:21:46 CDT 2019
On Tue, 2 Apr 2019, Victor Eijkhout via petsc-dev wrote:
> >> Configuring with elemental & 64-bit integers:
> >> Cannot use elemental with 64 bit BLAS/Lapack indices
> >> This used to work in 3.10. What changed?
> > with MKL?
> Yes.
> > Try:
> > https://bitbucket.org/petsc/petsc/pull-requests/1489/revert-commit-69ab9685009e-so-that-blas/diff#Lconfig/BuildSystem/config/packages/BlasLapack.pyF215T215
> Sorry, I’m not that much into git. Can you spell out how I get this applied and to what do I apply it to?
Since its a single commit - you can:
cd petsc-3.11.0
wget https://bitbucket.org/petsc/petsc/commits/6042f227ea50491e9afb70b084b0f7117c89ea5a/raw
patch -Np1 < raw
Satish
