[petsc-dev] git repo branches housekeeping
Hapla Vaclav
vaclav.hapla at erdw.ethz.ch
Mon Apr 1 14:57:08 CDT 2019
> On 1 Apr 2019, at 20:54, Balay, Satish via petsc-dev <petsc-dev at mcs.anl.gov> wrote:
> On Mon, 1 Apr 2019, Jed Brown wrote:
>> "Balay, Satish" <balay at mcs.anl.gov> writes:
>>> On Mon, 1 Apr 2019, Jed Brown via petsc-dev wrote:
>>>> "Smith, Barry F. via petsc-dev" <petsc-dev at mcs.anl.gov> writes:
>>>>> This is, IMHO, a weakness of git. It is crazy to impose this type of housekeeping directly on all 1000 users of a repository.
>>>> Perhaps this should be the default:
>>>> git config --global fetch.prune true
>>> or use 'git fetch -p' [ mentioned in my instructions]. I prefer
>>> 'fetch' to 'pull' anyway [as it keeps my git prompt sane] - so this
>>> works out well for me.
>>>> But, it would make it harder to recover if someone accidentally deletes
>>>> a branch on the server.
>>>> https://stackoverflow.com/a/40842589/33208
>>> This updates the origin/* references to remote branches - but does not
>>> delete locally checked out branches [if any] - they have to be
>>> manually deleted [as mentioned in my instructions]
>> Yes, but those are branches that a person has directly interacted with.
>> The many other branches would be quietly pruned.
> Agree..
> We could do:
> - try to close as many branches as possible on the server [with each PR].
Do you mean to tick the checkbox
Close <branch> after the pull request is merged
when creating a PR?
Vaclav
> - recommend folks use 'git config --global fetch.prune true' or 'git fetch -p' in their regular workflow.
> - folks could do housekeeping on their clones (aka delete local branches) at their own convenient schedule.
> - and I'll continue to send the 'housekeeping' e-mail reminder after release.
> Satish
