[petsc-dev] Can MATAIJ support block size?
Thu Sep 20 13:09:47 CDT 2018
On Thu, Sep 20, 2018 at 1:26 PM Fande Kong <fdkong.jd at gmail.com> wrote:
> Hi Developers,
> MATBAIJ actually assumes that the point-block is dense. It is fine if the
> block size is small for example less than 50, but we may suffer from a
> memory issue if the block is large such as 1000. The block is not necessary
> dense. In my application, neutron transport equations, the block is
> actually sparse (coming from direction and energy grids).  Now I am using
> MATAIJ, but I want to take into consideration there are many variables on
> each spatial grid when doing some ILU(0).  ILU(0) is used as a subdomain
> solver for ASM and BJACOBI.
> I would like to support point-block ILU(0) in MATAIJ (not MATBAIJ) because
> the block is sparse. Any comments? It is worthwhile to do that? I think we
> might reduce the symbolic factor time when considering the block.
What optimization do you hope to take advantage of? The main optimization
in sparse LU is finding dense blocks,
and it should do a good job of that. I do not see what defining huge,
sparse blocks does for you.
     Matt
> Thanks,
> Fande,
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180920/bdfe8a64/attachment.html>
