[petsc-dev] large bug in KSPSolve_Chebyshev() affects all multigrid solvers; all core developers including Mark please read this
Patrick Sanan patrick.sanan at gmail.com
Thu Sep 20 05:47:29 CDT 2018
2018-09-20 12:00 GMT+02:00 Mark Adams <mfadams at lbl.gov>:
> On Wed, Sep 19, 2018 at 7:44 PM Smith, Barry F. <bsmith at mcs.anl.gov>
> wrote:
>>     Look at the code in KSPSolve_Chebyshev().
>> Problem 1) VERY MAJOR
>>     Once you start running the eigenestimates it always runs them, this
>> is because the routine begins with
>>   if (cheb->kspest) {
>>    but once cheb->kspest is set it is never unset. This means, for
>> example, that every time PCMG runs the smoother that uses Chebyshev it runs
>> the eigenestimator (which uses GMRES) (even when it is suppose to be just
>> smoothing since the eigenestimates were already made in the setup stage).
>> This is totally wrong.
> Yikes, does this code (a few lines down) address this?
> if (amatid != cheb->amatid || pmatid != cheb->pmatid || amatstate !=
> cheb->amatstate || pmatstate != cheb->pmatstate) {
> Maybe you could run with CG as the outer solver and check that the number
> of GMRES solve calls (maybe with GMRESOrtho/max_it) is equal to the number
> of SNES iterations * (number of levels - 1).
If I run this
    ./ex19 -snes_monitor -ksp_view -pc_type mg -ksp_type gcr -pc_mg_levels 2
then I have one Chebyshev smoother (fine grid) and 2 SNES iterations, so
I'd expect 2 calls to KSPSolve_GMRES. That is what I see when I set a
breakpoint in gdb for KSPSolve_GMRES.
>> Sure enough, if I run, for example, src/snes/examples/tutorials/ex19.c
>> with -pc_type gamg I see in the debugger that GMRES is being called by
>> KSPSolve_Chebyshev as it smooths. For example,
>> 0  MatSOR (mat=0x28689f0, b=0x29ee310, omega=1, flag=28, shift=0, its=1,
>> lits=1, x=0x29f4070)
>>     at /sandbox/bsmith/petsc/src/mat/interface/matrix.c:3913
>> #1  0x00007f59d2e353b9 in PCApply_SOR (pc=0x29aa770, x=0x29ee310,
>> y=0x29f4070)
>>     at /sandbox/bsmith/petsc/src/ksp/pc/impls/sor/sor.c:31
>> #2  0x00007f59d2fa6a7b in PCApply (pc=0x29aa770, x=0x29ee310, y=0x29f4070)
>>     at /sandbox/bsmith/petsc/src/ksp/pc/interface/precon.c:462
>> #3  0x00007f59d2faa6a7 in PCApplyBAorAB (pc=0x29aa770, side=PC_LEFT,
>> x=0x29f11c0, y=0x29f4070, work=0x29ee310)
>>     at /sandbox/bsmith/petsc/src/ksp/pc/interface/precon.c:691
>> #4  0x00007f59d3084d46 in KSP_PCApplyBAorAB (ksp=0x29c4d30, x=0x29f11c0,
>> y=0x29f4070, w=0x29ee310)
>>     at /sandbox/bsmith/petsc/include/petsc/private/kspimpl.h:309
>> #5  0x00007f59d3086874 in KSPGMRESCycle (itcount=0x7ffd3d60143c,
>> ksp=0x29c4d30)
>>     at /sandbox/bsmith/petsc/src/ksp/ksp/impls/gmres/gmres.c:152
>> #6  0x00007f59d3087352 in KSPSolve_GMRES (ksp=0x29c4d30) at
>> /sandbox/bsmith/petsc/src/ksp/ksp/impls/gmres/gmres.c:234
>> #7  0x00007f59d30fae94 in KSPSolve (ksp=0x29c4d30, b=0x29dc900,
>> x=0x29d9a30)
>>     at /sandbox/bsmith/petsc/src/ksp/ksp/interface/itfunc.c:780
>> #8  0x00007f59d306a1e1 in KSPSolve_Chebyshev (ksp=0x29a9550) at
>> /sandbox/bsmith/petsc/src/ksp/ksp/impls/cheby/cheby.c:367
>> #9  0x00007f59d30fae94 in KSPSolve (ksp=0x29a9550, b=0x28653d0,
>> x=0x2906a70)
>> #10 0x00007f59d2f59042 in PCMGMCycle_Private (pc=0x2832fd0,
>> mglevelsin=0x2944b88, reason=0x0)
>>     at /sandbox/bsmith/petsc/src/ksp/pc/impls/mg/mg.c:20
>> #11 0x00007f59d2f5e350 in PCApply_MG (pc=0x2832fd0, b=0x28653d0,
>> x=0x2906a70)
>>     at /sandbox/bsmith/petsc/src/ksp/pc/impls/mg/mg.c:377
>> #12 0x00007f59d2fa6a7b in PCApply (pc=0x2832fd0, x=0x28653d0, y=0x2906a70)
>> #13 0x00007f59d31242d7 in KSP_PCApply (ksp=0x27df750, x=0x28653d0,
>> y=0x2906a70)
>>     at /sandbox/bsmith/petsc/include/petsc/private/kspimpl.h:281
>> #14 0x00007f59d31251ba in KSPInitialResidual (ksp=0x27df750,
>> vsoln=0x28610d0, vt1=0x28ff7b0, vt2=0x2903450,
>>     vres=0x2906a70, vb=0x28653d0) at /sandbox/bsmith/petsc/src/ksp/
>> ksp/interface/itres.c:67
>> #15 0x00007f59d30872ef in KSPSolve_GMRES (ksp=0x27df750) at
>> /sandbox/bsmith/petsc/src/ksp/ksp/impls/gmres/gmres.c:233
>> #16 0x00007f59d30fae94 in KSPSolve (ksp=0x27df750, b=0x28653d0,
>> x=0x28610d0)
>> #17 0x00007f59d3291d32 in SNESSolve_NEWTONLS (snes=0x26f2550) at
>> /sandbox/bsmith/petsc/src/snes/impls/ls/ls.c:224
>> #18 0x00007f59d320f7da in SNESSolve (snes=0x26f2550, b=0x0, x=0x285d440)
> Can this just be the first time it is called, so it is doing the setup?
>>   Not only is the code wrong but it is also a huge inefficiency in the
>> code running all these unneeded GMRES.
> Just to be clear, this is inefficiency, but I don't see why it is
> (mathematically) wrong.
>>   Problem 2) Less catastrophic
>>   When cheb->kspest is set the "regular" Chebyshev is also run (after the
>> eigenvalues are estimated).
> I don't see that. I see:
> static PetscErrorCode KSPSolve_Chebyshev(KSP ksp)
>   if (cheb->kspest) {
>        ... eig est
>  .. cheby ..
>> I am pretty sure this is wrong because there is no reason to run the
>> Chebyshev when estimating the eigenvalues? The eigenvalues are stored to be
>> used later right?
>>    So what needs to be fixed? Well somehow cheb->kspest has to be turned
>> off once the eigenvalues are computed, but turned back on each time the
>> matrix changes. And (easier) when cheb->kspest is used then the actual
>> Chebyshev iterations need to be turned off.
>>    I hope I am wrong and the code is correct but I'm pretty sure the code
>> is not what it should be.
>>    Barry
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180920/0ed0ed27/attachment-0001.html>
