[petsc-dev] Subsurface application and Algebraic Multigrid on GPUs
    Jed Brown
    jed at jedbrown.org
    Wed Sep 19 12:16:36 CDT 2018
Brian, how frequently do you need to update the matrix (thus rebuild the
preconditioner)?
If it is infrequent, we could (in the near term) provide AMG setup on
CPU with solves on GPU.
What is your typical problem size per node to be run on Summit?  What is
your MPI/OpenMP(?) decomposition?
Are these heterogeneous Poisson solves or are the equations to be solved
implicitly more complicated?  Do you have experimental information about
relative convergence rates/grid complexity/strong scalability for your
operator solved using classical AMG (e.g., Hypre) versus smoothed (or
plain) aggregation (ML, GAMG default)?
Brian Van Straalen <bvstraalen at lbl.gov> writes:
> So Baky and I have been at the Brookhaven GPU Hackathon now for three days,
> talking to everyone.  We have also been emailing with people who will
> respond to us from the hypre team and the PETSc team, as well as reading
> every blog post and mail archive and message board and from what we can
> tell, a distributed AMG preconditioner will not be available for us on a
> Summit platform for the foreseeable future.
> There is a hypre build for CUDA, but it has a problem with it's use of
> CUSP, and nobody seems to be working on it.
> PETSc has some .cu cuda files for the SpMV and Vector operations but the
> preconditioners are limited to point Jacobi and similar simple operations
> and a version of ILU.  Neither works for our stiff projection in the
> embedded boundary algorithms.   We built it and ran it and PETSc takes
> several hundred iterations to get the residual down by a factor of 6.  We
> need to get down to more like 10e-11 for this solve.
> The AMG being worked on by the NVIDIA team is not targeted for multi-node
> solving, and I haven't heard back from them in months.
>   We are left with two options as I see it to meet our ECP Milestones:
> 1. Build yet another interface, this time to see if there is a distributed
> GPU AMG preconditioner in Trilinos
>  2. Implement our own special-purpose EB-GMG solver written in Chombo.
> I would love to be wrong about all this.
> Brian
> Brian Van Straalen         Lawrence Berkeley Lab
> BVStraalen at lbl.gov        Computational Research
> (510) 486-4976            Division (crd.lbl.gov)
