I pushed the change to balay/remove-Regression.py Satish On Mon, 3 Sep 2018, Jose E. Roman wrote: > We are almost done with migrating SLEPc tests to the new test harness. If you want, you can remove Regression.py from PETSc, as well as any makefile rules that might remain for legacy tests. > > Jose >
