[petsc-dev] PETSc 3.10: September 4, 2018, is the cutoff-date for new features
    Karl Rupp
    rupp at iue.tuwien.ac.at
    Tue Sep  4 23:49:01 CDT 2018
Dear PETSc developers,
please open any outstanding pull requests for the upcoming PETSc 3.10
release in the next few hours. After that, please do not merge anything
to `next` or `master` unless it is integration work for existing open PRs.
You can open up new pull requests in the next days and weeks as usual.
If these are documentation enhancements, we will most likely integrate
them quickly. If these are bugfixes, we may still integrate them for
PETSc 3.10, decided on a per-case basis. New features, however, will not
be integrated until PETSc 3.10 is out.
Thanks and best regards,
Karli
> this is a gentle reminder for the cutoff-date on September 4.
> Best regards,
> Karli
>> in order to ensure a PETSc 3.10 release no later than by the end of
>> September (possibly earlier), we agreed on September 4, 2018, as the
>> cut-off date for new features. Please make sure that a pull request
>> has been opened on Bitbucket by this time. This is the preferred model
>> over merging to next directly, since our Jenkins test infrastructure
>> will test each PR separately (thus providing faster feedback and thus
>> allow for faster integration).
>> And while we are at it: Please keep in mind that new features also
>> require appropriate documentation. :-)
>> Karli
