[petsc-dev] Error running on Titan with GPUs & GNU
Mark Adams
mfadams at lbl.gov
Wed Oct 31 05:40:14 CDT 2018
It looks like configure is not finding the correct cc. It does not seem
hard to find.
06:37 master= /lustre/atlas/proj-shared/geo127/petsc$ cc --version
gcc (GCC) 6.3.0 20161221 (Cray Inc.)
Copyright (C) 2016 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
06:37 master= /lustre/atlas/proj-shared/geo127/petsc$ which cc
/opt/cray/craype/2.5.13/bin/cc
06:38 master= /lustre/atlas/proj-shared/geo127/petsc$ which gcc
/opt/gcc/6.3.0/bin/gcc
On Wed, Oct 31, 2018 at 6:34 AM Mark Adams <mfadams at lbl.gov> wrote:
> On Wed, Oct 31, 2018 at 5:05 AM Karl Rupp <rupp at iue.tuwien.ac.at> wrote:
>> Hi Mark,
>> please comment or remove lines 83 and 84 in
>> config/BuildSystem/config/packages/cuda.py
>> Is there a compiler newer than GCC 4.3 available?
> You mean 6.3?
> 06:33 ~$ module avail gcc
> ----------------------------------------------------- /opt/modulefiles
> gcc/4.8.1 gcc/4.9.3 gcc/6.1.0
> gcc/6.3.0(default) gcc/7.2.0
> gcc/4.8.2 gcc/5.3.0 gcc/6.2.0 gcc/7.1.0
> gcc/7.3.0
>> Best regards,
>> Karli
>> On 10/31/18 8:15 AM, Mark Adams via petsc-dev wrote:
>> > After loading a cuda module ...
>> > On Wed, Oct 31, 2018 at 2:58 AM Mark Adams <mfadams at lbl.gov
>> > <mailto:mfadams at lbl.gov>> wrote:
>> > I get an error with --with-cuda=1
>> > On Tue, Oct 30, 2018 at 4:44 PM Smith, Barry F. <bsmith at mcs.anl.gov
>> > <mailto:bsmith at mcs.anl.gov>> wrote:
>> > --with-cudac=1 should be --with-cuda=1
>> > > On Oct 30, 2018, at 12:35 PM, Smith, Barry F. via petsc-dev
>> > <petsc-dev at mcs.anl.gov <mailto:petsc-dev at mcs.anl.gov>> wrote:
>> > >> On Oct 29, 2018, at 8:09 PM, Mark Adams <mfadams at lbl.gov
>> > >> And a debug build seems to work:
>> > > Well ok.
>> > > Are there newer versions of the Gnu compiler for this
>> > system? Are there any other compilers on the system that would
>> > likely be less buggy? IBM compilers? If this simple code
>> > generates a gross error with optimization who's to say how many
>> > more subtle bugs may be induced in the library by the buggy
>> > optimizer (there may be none but IMHO probability says there
>> > will be others).
>> > > Is there any chance that valgrind runs on this machine;
>> > you could run the optimized version through it and see what it
>> says.
>> > > Barry
>> > >> 21:04 1 master= /lustre/atlas/proj-shared/geo127/petsc$ make
>> PETSC_DIR=/lustre/atlas/proj-shared/geo127/petsc_titan_dbg64idx_gnu_cuda
>> > PETSC_ARCH="" test
>> > >> Running test examples to verify correct installation
>> > >> Using
>> > and PETSC_ARCH=
>> > >> *******************Error detected during compile or
>> > link!*******************
>> > >> See http://www.mcs.anl.gov/petsc/documentation/faq.html
>> /lustre/atlas/proj-shared/geo127/petsc/src/snes/examples/tutorials
>> > ex19
>> > >> cc -o ex19.o -c -g
>> -I/lustre/atlas/proj-shared/geo127/petsc_titan_dbg64idx_gnu_cuda/include
>> `pwd`/ex19.c
>> > >> cc -g -o ex19 ex19.o
>> -L/lustre/atlas/proj-shared/geo127/petsc_titan_dbg64idx_gnu_cuda/lib
>> -Wl,-rpath,/lustre/atlas/proj-shared/geo127/petsc_titan_dbg64idx_gnu_cuda/lib
>> > -lpetsc -lHYPRE -lflapack -lfblas -lparmetis -lmetis -ldl
>> /lustre/atlas/proj-shared/geo127/petsc_titan_dbg64idx_gnu_cuda/lib/libpetsc.a(dlimpl.o):
>> > In function `PetscDLOpen':
>> /lustre/atlas1/geo127/proj-shared/petsc/src/sys/dll/dlimpl.c:108: warning:
>> > Using 'dlopen' in statically linked applications requires at
>> > runtime the shared libraries from the glibc version used for
>> linking
>> /lustre/atlas/proj-shared/geo127/petsc_titan_dbg64idx_gnu_cuda/lib/libpetsc.a(send.o):
>> > In function `PetscOpenSocket':
>> /lustre/atlas1/geo127/proj-shared/petsc/src/sys/classes/viewer/impls/socket/send.c:108:
>> > warning: Using 'gethostbyname' in statically linked applications
>> > requires at runtime the shared libraries from the glibc version
>> > used for linking
>> > >> true ex19
>> > >> rm ex19.o
>> > >> Possible error running C/C++
>> > src/snes/examples/tutorials/ex19 with 1 MPI process
>> > >> lid velocity = 0.0016, prandtl # = 1., grashof # = 1.
>> > >> Number of SNES iterations = 2
>> > >> Application 19081049 resources: utime ~1s, stime ~1s, Rss
>> > ~17112, inblocks ~36504, outblocks ~111043
>> > src/snes/examples/tutorials/ex19 with 2 MPI processes
>> > >> Application 19081050 resources: utime ~1s, stime ~1s, Rss
>> > ~19816, inblocks ~36527, outblocks ~111043
>> > >> 5a6
>> > >>> Application 19081051 resources: utime ~1s, stime ~0s, Rss
>> > ~13864, inblocks ~36527, outblocks ~111043
>> > >> Possible problem with ex19_hypre, diffs above
>> > ex5f
>> > >> ftn -c -g
>> > -o ex5f.o ex5f.F90
>> > >> ftn -g -o ex5f ex5f.o
>> linking
>> > used for linking
>> > >> rm ex5f.o
>> > >> Possible error running Fortran example
>> > src/snes/examples/tutorials/ex5f with 1 MPI process
>> > >> Number of SNES iterations = 4
>> > >> Application 19081055 resources: utime ~1s, stime ~0s, Rss
>> > ~12760, inblocks ~36800, outblocks ~111983
>> > >> Completed test examples
>> > >> 21:06 master= /lustre/atlas/proj-shared/geo127/petsc$
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20181031/66319c65/attachment-0001.html>
