[petsc-dev] Error running on Titan with GPUs & GNU
    Mark Adams
    mfadams at lbl.gov
    Wed Oct 31 02:15:41 CDT 2018
After loading a cuda module ...
On Wed, Oct 31, 2018 at 2:58 AM Mark Adams <mfadams at lbl.gov> wrote:
> I get an error with --with-cuda=1
> On Tue, Oct 30, 2018 at 4:44 PM Smith, Barry F. <bsmith at mcs.anl.gov>
> wrote:
>> --with-cudac=1 should be --with-cuda=1
>> > On Oct 30, 2018, at 12:35 PM, Smith, Barry F. via petsc-dev <
>> petsc-dev at mcs.anl.gov> wrote:
>> >> On Oct 29, 2018, at 8:09 PM, Mark Adams <mfadams at lbl.gov> wrote:
>> >> And a debug build seems to work:
>> >    Well ok.
>> >    Are there newer versions of the Gnu compiler for this system? Are
>> there any other compilers on the system that would likely be less buggy?
>> IBM compilers? If this simple code generates a gross error with
>> optimization who's to say how many more subtle bugs may be induced in the
>> library by the buggy optimizer (there may be none but IMHO probability says
>> there will be others).
>> >    Is there any chance that valgrind runs on this machine; you could
>> run the optimized version through it and see what it says.
>> >   Barry
>> >> 21:04 1 master= /lustre/atlas/proj-shared/geo127/petsc$ make
>> PETSC_DIR=/lustre/atlas/proj-shared/geo127/petsc_titan_dbg64idx_gnu_cuda
>> PETSC_ARCH="" test
>> >> Running test examples to verify correct installation
>> >> Using
>> and PETSC_ARCH=
>> >> *******************Error detected during compile or
>> link!*******************
>> >> See http://www.mcs.anl.gov/petsc/documentation/faq.html
>> >> /lustre/atlas/proj-shared/geo127/petsc/src/snes/examples/tutorials ex19
>> >> cc -o ex19.o -c -g
>>  -I/lustre/atlas/proj-shared/geo127/petsc_titan_dbg64idx_gnu_cuda/include
>>   `pwd`/ex19.c
>> >> cc -g  -o ex19 ex19.o
>> -L/lustre/atlas/proj-shared/geo127/petsc_titan_dbg64idx_gnu_cuda/lib
>> -Wl,-rpath,/lustre/atlas/proj-shared/geo127/petsc_titan_dbg64idx_gnu_cuda/lib
>> -lpetsc -lHYPRE -lflapack -lfblas -lparmetis -lmetis -ldl
>> /lustre/atlas/proj-shared/geo127/petsc_titan_dbg64idx_gnu_cuda/lib/libpetsc.a(dlimpl.o):
>> In function `PetscDLOpen':
>> >> /lustre/atlas1/geo127/proj-shared/petsc/src/sys/dll/dlimpl.c:108:
>> warning: Using 'dlopen' in statically linked applications requires at
>> runtime the shared libraries from the glibc version used for linking
>> /lustre/atlas/proj-shared/geo127/petsc_titan_dbg64idx_gnu_cuda/lib/libpetsc.a(send.o):
>> In function `PetscOpenSocket':
>> /lustre/atlas1/geo127/proj-shared/petsc/src/sys/classes/viewer/impls/socket/send.c:108:
>> warning: Using 'gethostbyname' in statically linked applications requires
>> at runtime the shared libraries from the glibc version used for linking
>> >> true ex19
>> >> rm ex19.o
>> >> Possible error running C/C++ src/snes/examples/tutorials/ex19 with 1
>> MPI process
>> >> lid velocity = 0.0016, prandtl # = 1., grashof # = 1.
>> >> Number of SNES iterations = 2
>> >> Application 19081049 resources: utime ~1s, stime ~1s, Rss ~17112,
>> inblocks ~36504, outblocks ~111043
>> >> Possible error running C/C++ src/snes/examples/tutorials/ex19 with 2
>> MPI processes
>> >> Application 19081050 resources: utime ~1s, stime ~1s, Rss ~19816,
>> inblocks ~36527, outblocks ~111043
>> >> 5a6
>> >>> Application 19081051 resources: utime ~1s, stime ~0s, Rss ~13864,
>> >> Possible problem with ex19_hypre, diffs above
>> >> /lustre/atlas/proj-shared/geo127/petsc/src/snes/examples/tutorials ex5f
>> >> ftn -c -g
>> -o ex5f.o ex5f.F90
>> >> ftn -g   -o ex5f ex5f.o
>> >> rm ex5f.o
>> >> Possible error running Fortran example
>> src/snes/examples/tutorials/ex5f with 1 MPI process
>> >> Number of SNES iterations =     4
>> >> Application 19081055 resources: utime ~1s, stime ~0s, Rss ~12760,
>> inblocks ~36800, outblocks ~111983
>> >> Completed test examples
>> >> 21:06 master= /lustre/atlas/proj-shared/geo127/petsc$
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20181031/a79216c9/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20181031/a79216c9/attachment-0001.obj>
