[petsc-dev] Error running on Titan with GPUs & GNU
Mark Adams
mfadams at lbl.gov
Tue Oct 30 14:18:03 CDT 2018
> Are there newer versions of the Gnu compiler for this system?
Yes:
/opt/modulefiles
gcc/4.8.1 gcc/4.8.2 gcc/4.9.3 gcc/5.3.0
gcc/6.1.0 gcc/6.2.0 gcc/6.3.0(default) gcc/7.1.0
gcc/7.2.0 gcc/7.3.0
> Are there any other compilers on the system that would likely be less
> buggy? IBM compilers? If this simple code generates a gross error with
> optimization who's to say how many more subtle bugs may be induced in the
> library by the buggy optimizer (there may be none but IMHO probability says
> there will be others).
Let me ask them what they recommend to use with cuda codes.
> Is there any chance that valgrind runs on this machine; you could run
> the optimized version through it and see what it says.
Valgrind works but tons of output and I could not see anything interesting
in there.
And, this test does work with 1 processor!
I think this is only a problem when GMRES is uses as the eigen estimator in
Cheby. GMRES solvers work and Cheby works with -mg_levels_esteig_ksp_type
cg.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20181030/4e794d05/attachment.html>
