[petsc-dev] Error running on Titan with GPUs & GNU
    Mark Adams
    mfadams at lbl.gov
    Mon Oct 29 16:15:31 CDT 2018
On Mon, Oct 29, 2018 at 5:07 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Oct 29, 2018 at 5:01 PM Mark Adams via petsc-dev <
> petsc-dev at mcs.anl.gov> wrote:
>> I get this error running the tests using GPUs. An error in an LAPACK
>> routine.
> From the command line, it does not look like GPUs are being used.
> It looks like the LAPACK eigensolver is failing. Maybe there is a variant
> signature on this machine?
I am not doing anything with LAPACK. I have no ideas what LAPACK it is
picking up. I do notice in the configure log that hypre has LAPACK stuff
embedding in it.  (PETSc is not using hyper's LAPACK is it?).
I can try downloading blaslapack ....
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20181029/a2915efd/attachment.html>
