[petsc-dev] Problem with DMKSP/DMSNES and GMG
    Matthew Knepley
    knepley at gmail.com
    Fri Oct 26 12:13:18 CDT 2018
On Fri, Oct 26, 2018 at 12:13 PM Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> >> > On Fri, Oct 26, 2018 at 11:06 AM Jed Brown <jed at jedbrown.org> wrote:
> >> >> > I am having a problem, and every solution I can think of would seem
> >> to do
> >> >> > violence to encapsulation or to DMKSP/DMSNES.
> >> >> > I want to have GMG automatically work on the velocity part of
> Stokes.
> >> So
> >> >> I
> >> >> > give
> >> >> >   -fieldsplit_velocity_pc_type mg
> >> >> > in SNES ex62. This complains that the KSP has a DM but
> >> >> > KSPSetComputeOperator() has not been called. It is fine on the
> global
> >> >> > system because SNES called that in SNESSetupMatrices(). Thus in
> >> >> FieldSplit,
> >> >> > I inserted
> >> >> >             PetscErrorCode (*func)(KSP,Mat,Mat,void*);
> >> >> >             void            *ctx;
> >> >> >             ierr = DMKSPGetComputeOperators(pc->dm, &func,
> >> >> > &ctx);CHKERRQ(ierr);
> >> >> >             ierr = DMKSPSetComputeOperators(dms[i],  func,
> >> >> > ctx);CHKERRQ(ierr);
> >> >> Wait, pc->dm is the coupled system while each dms[i] is a component
> >> >> (like velocity).  It would be awkward to ask the user to write a
> single
> >> >> function that would inspect the DM to figure out what sort of
> problem it
> >> >> was discretizing (velocity-only, pressure-only,
> >> >> velocity-pressure-coupled, etc.).  Do you currently have a
> >> >> ComputeOperators for each sub-problem?
> >> > CreateSubDM() returns a DM whose DS only involves the subset of
> fields.
> >> DS?  That isn't really a DM-level concept; I see you use it in a couple
> >> utility functions in DMDA, but it isn't part of the solver-related
> >> functionality.  In any case, the code you wrote above looks to be moving
> >> the outer ComputeOperators onto a sub-DM, which can't possibly be a
> >> desirable solution.  Why can't DMCreateSubDM ensure that each sub DM is
> >> endowed with whatever discretization functionality is known?
> > As I said in my reply, it already does this. HOWEVER, it cannot move the
> > construction functions from the old DMSNES to the subDMSNES, because it
> > does not know about SNES.
> DMSNES could register a callback to decompose itself for DMCreateSubDM.
> We do something similar in DMRestrictHook, for example.
It looks like we will have to add a hook in order to break dependency
cycles. I will
do it.
   Matt
> Alternatively, the user could create the subDMs and endow them with
> functionality.  You'd probably want DMGetSubDM for that since the parent
> DM would maintain ownership.
> >> > Thus, only
> >> > the v-v block is present in the subDM, and when the SNES assembly
> >> functions
> >> > is called,
> >> > it forms that block. I just need that function to be called.
> >> Is it really the same function as is used by the outer DM?
> > Yes.
> > You are not addressing the question.
> I just wanted to clarify whether you thought that was something that
> could possibly be merged or just an attempted dirty hack.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20181026/e430a74d/attachment.html>
