[petsc-dev] Problem with DMKSP/DMSNES and GMG
    Jed Brown
    jed at jedbrown.org
    Fri Oct 26 10:06:51 CDT 2018
Matthew Knepley <knepley at gmail.com> writes:
> I am having a problem, and every solution I can think of would seem to do
> violence to encapsulation or to DMKSP/DMSNES.
> I want to have GMG automatically work on the velocity part of Stokes. So I
> give
>   -fieldsplit_velocity_pc_type mg
> in SNES ex62. This complains that the KSP has a DM but
> KSPSetComputeOperator() has not been called. It is fine on the global
> system because SNES called that in SNESSetupMatrices(). Thus in FieldSplit,
> I inserted
>             PetscErrorCode (*func)(KSP,Mat,Mat,void*);
>             void            *ctx;
>             ierr = DMKSPGetComputeOperators(pc->dm, &func,
> &ctx);CHKERRQ(ierr);
>             ierr = DMKSPSetComputeOperators(dms[i],  func,
> ctx);CHKERRQ(ierr);
Wait, pc->dm is the coupled system while each dms[i] is a component
(like velocity).  It would be awkward to ask the user to write a single
function that would inspect the DM to figure out what sort of problem it
was discretizing (velocity-only, pressure-only,
velocity-pressure-coupled, etc.).  Do you currently have a
ComputeOperators for each sub-problem?
> where we call KSPSetDM(). However, this does not work, because the subDM
> has a new DMSNES, which does not have the information about the problem.
> Solution #1:
>   Copy the info from the old DMSNES to the subDMSNES. This inserts a
> dependence between KSP and SNES which we do not want.
> Solution #2:
>   Have DMCreateSubDM() copy everything from the solvers. This also inserts
> dependencies, unless we have a "copy everything" mechanism, but is this
> what we want.
> Solution #3:
>   Rethink DMKSP/DMSNES. Is this how we should store problem information.
> Dave already had another problem with the organization.
> What should be done? I have never understood this construct very well.
> Right now, this is holding up doing some computations I need.
>   Thanks,
>      Matt
> experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
