[petsc-dev] --download and spack
Balay, Satish
balay at mcs.anl.gov
Sun Oct 21 12:55:01 CDT 2018
All compilers need to be preconfigured. [with 'spack compiler find' -
which I think gets auto-invoked the first time 'spack install' is
invoked]
[balay at fedora spack]$ spack compiler list
==> Available compilers
-- clang fedora29-x86_64 ----------------------------------------
clang at 7.0.0
-- gcc fedora29-x86_64 ------------------------------------------
gcc at 8.2.1
[balay at fedora ~]$
for clang - it doesn't automatically associate a fortran compiler - so
one would have to manually add gfortran to
~/.spack/linux/compilers.yaml [on linux]
And then - it uses the last entry as the default [one can manually
specify a different default in ~/.spack/packages.py]
So you can do:
[install with default compilers - in this case gcc at 8.2.1]
spack install petsc
[install with a non-default compilers - in this case clang at 7.0.0]
spack install petsc%clang at 7.0.0
Satish
On Sun, 21 Oct 2018, Smith, Barry F. wrote:
> How does one set the compiler for Spack to use. I read all of https://spack.readthedocs.io/en/latest/getting_started.html and it showed how to find compilers and add them to the spack compiler list but nothing about how to tell spack to use a particular compiler?
> > On Oct 21, 2018, at 11:51 AM, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> > Needs some more work
> > ./bin/spack install petsc+hypre
> > ==> mpich at 3.2 : externally installed in /usr/local
> > ==> mpich at 3.2 : generating module file
> > ==> mpich at 3.2 : registering into DB
> > ==> zlib at 1.2.8 : externally installed in /usr
> > ==> zlib at 1.2.8 : generating module file
> > ==> zlib at 1.2.8 : registering into DB
> > ==> Installing hdf5
> > ==> Fetching https://support.hdfgroup.org/ftp/HDF5/releases/hdf5-1.10/hdf5-1.10.3/src/hdf5-1.10.3.tar.gz
> > ######################################################################## 100.0%
> > ==> Staging archive: /Users/barrysmith/Src/spack/var/spack/stage/hdf5-1.10.3-qe62ngz3szijov3frsc6sclbfylst3qk/hdf5-1.10.3.tar.gz
> > ==> Created stage in /Users/barrysmith/Src/spack/var/spack/stage/hdf5-1.10.3-qe62ngz3szijov3frsc6sclbfylst3qk
> > ==> No patches needed for hdf5
> > ==> Building hdf5 [AutotoolsPackage]
> > ==> Executing phase: 'autoreconf'
> > ==> Executing phase: 'configure'
> > ==> Executing phase: 'build'
> > ==> Executing phase: 'install'
> > ==> Successfully installed hdf5
> > Fetch: 4.37s. Build: 2m 5.47s. Total: 2m 9.84s.
> > [+] /Users/barrysmith/Src/spack/opt/spack/darwin-mojave-x86_64/clang-10.0.0-apple/hdf5-1.10.3-qe62ngz3szijov3frsc6sclbfylst3qk
> > ==> Installing veclibfort
> > ==> Fetching https://github.com/mcg1969/vecLibFort/archive/0.4.2.tar.gz
> > ==> Staging archive: /Users/barrysmith/Src/spack/var/spack/stage/veclibfort-0.4.2-jgzyxocuu54r2lqckfugttbk3gpvhthk/0.4.2.tar.gz
> > ==> Created stage in /Users/barrysmith/Src/spack/var/spack/stage/veclibfort-0.4.2-jgzyxocuu54r2lqckfugttbk3gpvhthk
> > ==> No patches needed for veclibfort
> > ==> Building veclibfort [Package]
> > ==> Successfully installed veclibfort
> > Fetch: 1.02s. Build: 1.73s. Total: 2.75s.
> > [+] /Users/barrysmith/Src/spack/opt/spack/darwin-mojave-x86_64/clang-10.0.0-apple/veclibfort-0.4.2-jgzyxocuu54r2lqckfugttbk3gpvhthk
> > ==> Installing hypre
> > ==> Fetching https://github.com/LLNL/hypre/archive/v2.15.0.tar.gz
> > ==> Staging archive: /Users/barrysmith/Src/spack/var/spack/stage/hypre-2.15.0-zzqagb6smd7uzznitrlvx3eor4oay3dg/v2.15.0.tar.gz
> > ==> Created stage in /Users/barrysmith/Src/spack/var/spack/stage/hypre-2.15.0-zzqagb6smd7uzznitrlvx3eor4oay3dg
> > ==> No patches needed for hypre
> > ==> Building hypre [Package]
> > ==> Successfully installed hypre
> > Fetch: 1.68s. Build: 45.02s. Total: 46.70s.
> > [+] /Users/barrysmith/Src/spack/opt/spack/darwin-mojave-x86_64/clang-10.0.0-apple/hypre-2.15.0-zzqagb6smd7uzznitrlvx3eor4oay3dg
> > ==> cmake at 3.7.1 : externally installed in /usr/local/bin
> > ==> cmake at 3.7.1 : generating module file
> > ==> cmake at 3.7.1 : registering into DB
> > ==> Installing metis
> > ==> Fetching http://glaros.dtc.umn.edu/gkhome/fetch/sw/metis/metis-5.1.0.tar.gz
> > ==> Staging archive: /Users/barrysmith/Src/spack/var/spack/stage/metis-5.1.0-x7k25qyuivjq4t4jb32gxagfa3qc4b3y/metis-5.1.0.tar.gz
> > ==> Created stage in /Users/barrysmith/Src/spack/var/spack/stage/metis-5.1.0-x7k25qyuivjq4t4jb32gxagfa3qc4b3y
> > ==> Applied patch install_gklib_defs_rename.patch
> > ==> Ran patch() for metis
> > ==> Building metis [Package]
> > ==> Successfully installed metis
> > Fetch: 3.86s. Build: 8.33s. Total: 12.19s.
> > [+] /Users/barrysmith/Src/spack/opt/spack/darwin-mojave-x86_64/clang-10.0.0-apple/metis-5.1.0-x7k25qyuivjq4t4jb32gxagfa3qc4b3y
> > ==> Installing parmetis
> > ==> Fetching http://glaros.dtc.umn.edu/gkhome/fetch/sw/parmetis/parmetis-4.0.3.tar.gz
> > ==> Staging archive: /Users/barrysmith/Src/spack/var/spack/stage/parmetis-4.0.3-st6cbngrj2r5jgtenru4f6jbtrbvhp3h/parmetis-4.0.3.tar.gz
> > ==> Created stage in /Users/barrysmith/Src/spack/var/spack/stage/parmetis-4.0.3-st6cbngrj2r5jgtenru4f6jbtrbvhp3h
> > ==> Applied patch enable_external_metis.patch
> > ==> Applied patch pkg-parmetis-1c1a9fd0f408dc4d42c57f5c3ee6ace411eb222b.patch
> > ==> Applied patch pkg-parmetis-82409d68aa1d6cbc70740d0f35024aae17f7d5cb.patch
> > ==> Building parmetis [CMakePackage]
> > ==> Executing phase: 'cmake'
> > ==> Successfully installed parmetis
> > Fetch: 3.71s. Build: 8.08s. Total: 11.79s.
> > [+] /Users/barrysmith/Src/spack/opt/spack/darwin-mojave-x86_64/clang-10.0.0-apple/parmetis-4.0.3-st6cbngrj2r5jgtenru4f6jbtrbvhp3h
> > ==> python at 2.7.1 : externally installed in /usr
> > ==> python at 2.7.1 : generating module file
> > ==> python at 2.7.1 : registering into DB
> > ==> Installing superlu-dist
> > ==> Fetching https://github.com/xiaoyeli/superlu_dist/archive/v5.4.0.tar.gz
> > ==> Staging archive: /Users/barrysmith/Src/spack/var/spack/stage/superlu-dist-5.4.0-zfeg63fl3jxidb2irxucgz7nvmintbzn/v5.4.0.tar.gz
> > ==> Created stage in /Users/barrysmith/Src/spack/var/spack/stage/superlu-dist-5.4.0-zfeg63fl3jxidb2irxucgz7nvmintbzn
> > ==> No patches needed for superlu-dist
> > ==> Building superlu-dist [CMakePackage]
> > ==> Successfully installed superlu-dist
> > Fetch: 2.03s. Build: 22.54s. Total: 24.57s.
> > [+] /Users/barrysmith/Src/spack/opt/spack/darwin-mojave-x86_64/clang-10.0.0-apple/superlu-dist-5.4.0-zfeg63fl3jxidb2irxucgz7nvmintbzn
> > ==> Installing petsc
> > ==> Fetching http://ftp.mcs.anl.gov/pub/petsc/release-snapshots/petsc-3.10.2.tar.gz
> > ==> Staging archive: /Users/barrysmith/Src/spack/var/spack/stage/petsc-3.10.2-7fmmtqrr42secdvbosssdjc5lxnohh6b/petsc-3.10.2.tar.gz
> > ==> Created stage in /Users/barrysmith/Src/spack/var/spack/stage/petsc-3.10.2-7fmmtqrr42secdvbosssdjc5lxnohh6b
> > ==> No patches needed for petsc
> > ==> Building petsc [Package]
> > ==> Error: ProcessError: Command exited with status 2:
> > 'make' 'MAKE_NP=8'
> > 1 error found in build log:
> > 52
> > 53 ==> 'make' 'MAKE_NP=8'
> > 54 makefile:15: lib/petsc/conf/petscvariables: No such file or directory
> > 55 makefile:16: /lib/petsc/conf/variables: No such file or directory
> > 56 makefile:17: /lib/petsc/conf/rules: No such file or directory
> > 57 makefile:18: /lib/petsc/conf/test.common: No such file or directory
> >>> 58 make: *** No rule to make target `/lib/petsc/conf/test.common'. Stop.
> > See build log for details:
> > /Users/barrysmith/Src/spack/var/spack/stage/petsc-3.10.2-7fmmtqrr42secdvbosssdjc5lxnohh6b/petsc-3.10.2/spack-build.out
> > Then in the build log
> > File "/private/var/folders/c1/ldz_dt8n2r3dtwv_chp5pfr40000gn/T/barrysmith/spack-stage/spack-stage-hFL0xI/petsc-3.10.2/config/BuildSystem/nargs.py", line 360, in setValue
> > raise ValueError('Invalid directory: '+str(dir)+' for key '+str(self.key))
> > Configuring PETSc to compile on your system
> > ERROR in COMMAND LINE ARGUMENT to ./configure
> > Invalid directory: /usr/include for key with-zlib-include
> > Apple OS doesn't come with a /usr/include
> >> On Oct 20, 2018, at 10:47 PM, Jed Brown <jed at jedbrown.org> wrote:
> >> We're currently maintaining a (somewhat clumsy and limited, albeit
> >> functional) package manager in the form of the --download functionality.
> >> What do people think of outsourcing this to Spack, which would handle
> >> dependency resolution and report includes/libraries to PETSc? That
> >> would enable reuse of installed packages between different PETSC_ARCH
> >> and be more reliable regarding upgrade/downgrade when switching
> >> branches.
