[petsc-dev] MatNest and MatCreateHermitianTranspose
    Stefano Zampini
    stefano.zampini at gmail.com
    Sat Oct 20 02:22:00 CDT 2018
Pierre,
Thanks to report this. I think this should be fixed in
MatHermitianTransposeAdd. Would you like to open a PR?
Thanks
Stefani
Il Sab 20 Ott 2018, 08:16 Pierre Jolivet <pierre.jolivet at enseeiht.fr> ha
scritto:
> Hello,
> I’m using a MatNest with some blocks made of matrices created with
> MatCreateHermitianTranspose. I end up with the following trace when doing a
> simple MatMult.
> Should this be fixed in matnest.c, matrix.c or htransm.c?
> Thanks,
> Pierre
> (lldb) down
> frame #11: 0x000000011ad06830
> libpetsc.3.010.dylib`MatMult_Nest(A=0x00007fcc2eb50260,
> x=0x00007fcc2f019460, y=0x00007fcc2f01ca60) at matnest.c:52
>    49       for (j=0; j<nc; j++) {
>    50         if (!bA->m[i][j]) continue;
>    51         /* y[i] <- y[i] + A[i][j] * x[j] */
> -> 52         ierr =
> MatMultAdd(bA->m[i][j],bx[j],by[i],by[i]);CHKERRQ(ierr);
>    53       }
>    54     }
>    55     for (i=0; i<nr; i++) {ierr =
> VecRestoreSubVector(y,bA->isglobal.row[i],&by[i]);CHKERRQ(ierr);}
> (lldb)
> frame #10: 0x000000011a9d6399
> libpetsc.3.010.dylib`MatMultAdd(mat=0x00007fcc2ebfde60,
> v1=0x00007fcc2f029c60, v2=0x00007fcc2f024660, v3=0x00007fcc2f024660) at
> matrix.c:2517
>    2514   if (!mat->ops->multadd)
> SETERRQ1(PetscObjectComm((PetscObject)mat),PETSC_ERR_SUP,"No MatMultAdd()
> for matrix type '%s'",((PetscObject)mat)->type_name);
>    2515   ierr =
> PetscLogEventBegin(MAT_MultAdd,mat,v1,v2,v3);CHKERRQ(ierr);
>    2516   ierr = VecLockPush(v1);CHKERRQ(ierr);
> -> 2517   ierr = (*mat->ops->multadd)(mat,v1,v2,v3);CHKERRQ(ierr);
>    2518   ierr = VecLockPop(v1);CHKERRQ(ierr);
>    2519   ierr = PetscLogEventEnd(MAT_MultAdd,mat,v1,v2,v3);CHKERRQ(ierr);
>    2520   ierr = PetscObjectStateIncrease((PetscObject)v3);CHKERRQ(ierr);
> (lldb)
> frame #9: 0x000000011ad136d0
> libpetsc.3.010.dylib`MatMultAdd_HT(N=0x00007fcc2ebfde60,
> htransm.c:24
>    21     PetscErrorCode ierr;
>    22
>    23     PetscFunctionBegin;
> -> 24     ierr =
> MatMultHermitianTransposeAdd(Na->A,v1,v2,v3);CHKERRQ(ierr);
>    25     PetscFunctionReturn(0);
>    26   }
>    27
> (lldb)
> frame #8: 0x000000011a9d88e5
> libpetsc.3.010.dylib`MatMultHermitianTransposeAdd(mat=0x00007fcc2e977260,
> matrix.c:2629
>    2626     ierr = MatMultTranspose(mat,w,z);CHKERRQ(ierr);
>    2627     ierr = VecDestroy(&w);CHKERRQ(ierr);
>    2628     ierr = VecConjugate(z);CHKERRQ(ierr);
> -> 2629     ierr = VecWAXPY(v3,1.0,v2,z);CHKERRQ(ierr);
>    2630     ierr = VecDestroy(&z);CHKERRQ(ierr);
>    2631   }
>    2632   ierr = VecLockPop(v1);CHKERRQ(ierr);
> (lldb)
> frame #7: 0x000000011a8f33b5
> libpetsc.3.010.dylib`VecWAXPY(w=0x00007fcc2f024660, alpha=1,
> x=0x00007fcc2f024660, y=0x00007fcc2f039260) at rvector.c:795
>    792    VecCheckSameSize(x,3,y,4);
>    793    VecCheckSameSize(x,3,w,1);
>    794    if (w == y) SETERRQ(PETSC_COMM_SELF,PETSC_ERR_SUP,"Result vector
> w cannot be same as input vector y, suggest VecAXPY()");
> -> 795    if (w == x) SETERRQ(PETSC_COMM_SELF,PETSC_ERR_SUP,"Result vector
> w cannot be same as input vector x, suggest VecAYPX()");
>    796    PetscValidLogicalCollectiveScalar(y,alpha,2);
>    797
>    798    ierr = PetscLogEventBegin(VEC_WAXPY,x,y,w,0);CHKERRQ(ierr);
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20181020/1b394ac0/attachment.html>
