[petsc-dev] MatHermitianTransposeGetMat
Dave May
dave.mayhem23 at gmail.com
Fri Oct 19 16:10:50 CDT 2018
Hi Pierre,
On Fri, 19 Oct 2018 at 21:28, Pierre Jolivet <pierre.jolivet at enseeiht.fr>
wrote:
> Hello,
> I’m trying to call MatTransposeGetMat on a Mat created with
> MatCreateHermitianTranspose, but this fails.
> Why is there no MatHermitianTransposeGetMat?
Looks like an oversight to me.
Is there a work around?
Doesn't seem to be a hack workaround possible as the object holding the
reference to the original matrix is declared directly in the C file. See
typedef struct Mat_HT
https://www.mcs.anl.gov/petsc/petsc-current/src/mat/impls/transpose/htransm.c.html
Support for XXXGetMat() needs to go into master. Essentially one needs to
just copy the code from
https://www.mcs.anl.gov/pets/petsc-current/src/mat/impls/transpose/transm.c.html
associated with MatTransposeGetMat and change the type from Mat_Transpose
to Mat_HT.
Want to make a PR?
Cheers,
Dave
> Thanks,
> Pierre
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20181019/eae2b1ec/attachment.html>
