[petsc-dev] MUMPS silent errors
    Zhang, Junchao
    jczhang at mcs.anl.gov
    Thu Oct 11 10:40:22 CDT 2018
Hong,
 The user's example code reads a matrix, calls KSPSolve, then over. From his  log_view file, I saw long MatLUFactorNum time and short MatSolve time.  Now I know that is because MatSolve was skipped. Thanks.
Sent: Thursday, October 11, 2018 10:07:10 AM
To: Zhang, Junchao
Cc: Smith, Barry F.; For users of the development version of PETSc
Subject: Re: [petsc-dev] MUMPS silent errors
Junchao :
When matrix factorization fails, we diver error message back to user and skip MatSolve. Can you reproduce this problem and I'll take a look at it?
What is embarrassing is the user sent me beautiful -log_view outputs and began doing performance comparison. The whole thing is meaningless only because he forgot to check the converged reason on a direct solver.
When linear solver fails, snes/ts also fails, which should display error output to user. User should check the accuracy of his final solution with '-snes_converged_reason' before looking at performance.
MUMPS manual has "A call to MUMPS with JOB=2 must be preceded by a call with JOB=1 on the same instance", and similar languages for other phases.  It implies we at least should not call MatSolve_MUMPS with failed factorization since it might crash the code.
Yes. I've never seen this happen before, thus want to check.
Hong
Sent: Wednesday, October 10, 2018 6:41:20 PM
To: Zhang, Junchao
Cc: petsc-dev
  I looked at the code and it is handled in the PETSc way. The user should not expect KSP to error just because it was unable to solve a linear system; they should be calling KSPGetConvergedReason() after KSPSolve() to check that the solution was computed successfully.
   Barry
> On Oct 10, 2018, at 2:12 PM, Zhang, Junchao <jczhang at mcs.anl.gov<mailto:jczhang at mcs.anl.gov>> wrote:
> I met a case where MUMPS numeric factorization returned an error code -9 in mumps->id.INFOG(1) but A->erroriffailure was false in the following code in mumps.c
> 1199: PetscErrorCode MatFactorNumeric_MUMPS(Mat F,Mat A,const MatFactorInfo *info)
> 1200:
> 1227:   PetscMUMPS_c(mumps);
> 1228:   if
>  (mumps->id.INFOG(1) < 0) {
> 1229:     if
>  (A->erroriffailure) {
> 1230:       SETERRQ2(PETSC_COMM_SELF,PETSC_ERR_LIB,"Error reported by MUMPS in numerical factorization phase: INFOG(1)=%d, INFO(2)=%d\n"
> ,mumps->id.INFOG(1),mumps->id.INFO(2));
> 1231:     } else
> 1232:       if (mumps->id.INFOG(1) == -10) { /* numerically singular matrix */
> 1233:         PetscInfo2(F,"matrix is numerically singular, INFOG(1)=%d, INFO(2)=%d\n"
> 1234:
>         F->factorerrortype = MAT_FACTOR_NUMERIC_ZEROPIVOT;
> The code continued to KSPSolve and finished successfully (with wrong answer). The user did not call KSPGetConvergedReason() after KSPSolve. I found I had  to either add -ksp_error_if_not_converged or call KSPSetErrorIfNotConverged(ksp,PETSC_TRUE) to make the code fail.
> Is it expected?  In my view, it is dangerous. If MUMPS fails in one stage, PETSc should not proceed to the next stage because it may hang there.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20181011/b5eb0076/attachment.html>
