[petsc-dev] Fortran interface problem in v.3.10.2
Martin Diehl m.diehl at mpie.de
Fri Nov 9 00:19:10 CST 2018
Hi Adrian,
thanks.
Please find attached the modified version of the example.
Seems to work (at least compiles)
Martin
On Fri, 2018-11-09 at 13:04 +1300, Adrian Croucher wrote:
> hi Martin,
> Sure, here it is.
> - Adrian
> On 9/11/18 12:34 PM, Martin Diehl wrote:
> > Dear Adrian,
> > I looked into the issue of passing in derived types with type bound
> > procedures again and it seems that casting to C pointers is a
> > suitable
> > alternative.
> > To investigate that, I modified ex5f.F90 from
> > src/snes/examples/tutorials in a branch of my PETSc fork:
> > https://bitbucket.org/m_diehl/petsc/src/5172a911a5cc8a6228f00f2435cc5cfe6ec569d9/?at=m.diehl%2FSNESSetConvergenceTestTypeFortran
> > Could you please send me your original minimal working example
> > again?
> > I've deleted it and would like to test the new approach there also.
> > many thanks
> > Martin
Max-Planck-Institut für Eisenforschung GmbH
Max-Planck-Straße 1
D-40237 Düsseldorf
Handelsregister B 2533
Amtsgericht Düsseldorf
Geschäftsführung
Prof. Dr. Gerhard Dehm
Prof. Dr. Jörg Neugebauer
Prof. Dr. Dierk Raabe
Dr. Kai de Weldige
Ust.-Id.-Nr.: DE 11 93 58 514
Steuernummer: 105 5891 1000
Please consider that invitations and e-mails of our institute are
only valid if they end with …@mpie.de.
If you are not sure of the validity please contact rco at mpie.de
Bitte beachten Sie, dass Einladungen zu Veranstaltungen und E-Mails
aus unserem Haus nur mit der Endung …@mpie.de gültig sind.
In Zweifelsfällen wenden Sie sich bitte an rco at mpie.de
Type: text/x-fortran
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20181109/a805be33/attachment.bin>
Desc: This is a digitally signed message part
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20181109/a805be33/attachment.sig>
