[petsc-dev] tests with multiple loops
Hapla Vaclav
vaclav.hapla at erdw.ethz.ch
Thu Nov 8 09:40:43 CST 2018
Assume the following test
test:
suffix: 4_tet_test_orient
nsize: 2
args: -dim 3 -distribute 0
args: -rotate_interface_0 {{0 1 2 11 12 13}}
args: -rotate_interface_1 {{0 1 2 11 12 13}}
I was thinking that it should produce all combinations of -rotate_interface_0 and -rotate_interface_1, i.e. 6*6*2 = 72 tests including diffs.
But instead it produces only 22 tests for me. I guess it's wrong, isn't it?
Thanks
Vaclav
ok dm_impls_plex_tests-ex18_4_tet_test_orient_rotate_interface_0-0_rotate_interface_1-0
ok diff-dm_impls_plex_tests-ex18_4_tet_test_orient_rotate_interface_0-0_rotate_interface_1-0
ok dm_impls_plex_tests-ex18_4_tet_test_orient_rotate_interface_0-0_rotate_interface_1-1
ok diff-dm_impls_plex_tests-ex18_4_tet_test_orient_rotate_interface_0-0_rotate_interface_1-1
ok dm_impls_plex_tests-ex18_4_tet_test_orient_rotate_interface_0-0_rotate_interface_1-2
ok diff-dm_impls_plex_tests-ex18_4_tet_test_orient_rotate_interface_0-0_rotate_interface_1-2
ok dm_impls_plex_tests-ex18_4_tet_test_orient_rotate_interface_0-0_rotate_interface_1-11
ok diff-dm_impls_plex_tests-ex18_4_tet_test_orient_rotate_interface_0-0_rotate_interface_1-11
ok dm_impls_plex_tests-ex18_4_tet_test_orient_rotate_interface_0-0_rotate_interface_1-12
ok diff-dm_impls_plex_tests-ex18_4_tet_test_orient_rotate_interface_0-0_rotate_interface_1-12
ok dm_impls_plex_tests-ex18_4_tet_test_orient_rotate_interface_0-0_rotate_interface_1-13
ok diff-dm_impls_plex_tests-ex18_4_tet_test_orient_rotate_interface_0-0_rotate_interface_1-13
ok dm_impls_plex_tests-ex18_4_tet_test_orient_rotate_interface_0-1_rotate_interface_1-13
ok diff-dm_impls_plex_tests-ex18_4_tet_test_orient_rotate_interface_0-1_rotate_interface_1-13
ok dm_impls_plex_tests-ex18_4_tet_test_orient_rotate_interface_0-2_rotate_interface_1-13
ok diff-dm_impls_plex_tests-ex18_4_tet_test_orient_rotate_interface_0-2_rotate_interface_1-13
ok dm_impls_plex_tests-ex18_4_tet_test_orient_rotate_interface_0-11_rotate_interface_1-13
ok diff-dm_impls_plex_tests-ex18_4_tet_test_orient_rotate_interface_0-11_rotate_interface_1-13
ok dm_impls_plex_tests-ex18_4_tet_test_orient_rotate_interface_0-12_rotate_interface_1-13
ok diff-dm_impls_plex_tests-ex18_4_tet_test_orient_rotate_interface_0-12_rotate_interface_1-13
ok dm_impls_plex_tests-ex18_4_tet_test_orient_rotate_interface_0-13_rotate_interface_1-13
ok diff-dm_impls_plex_tests-ex18_4_tet_test_orient_rotate_interface_0-13_rotate_interface_1-13
# Summary
# success 22/22 tests (100.0%)
# failed 0/22 tests (0.0%)
# todo 0/22 tests (0.0%)
# skip 0/22 tests (0.0%)
