[petsc-dev] Error running on Titan with GPUs & GNU
    Mark Adams
    mfadams at lbl.gov
    Fri Nov  2 13:25:52 CDT 2018
And I just tested it with GAMG and it seems fine.  And hypre ran, but it is
not clear that it used GPUs....
14:13 master= ~/petsc/src/snes/examples/tutorials$ jsrun -n 1 ./ex19
-dm_vec_type cuda -dm_mat_type aijcusparse -pc_type hypre -ksp_type fgmres
-snes_monitor_short -snes_rtol 1.e-5 -ksp_view
lid velocity = 0.0625, prandtl # = 1., grashof # = 1.
  0 SNES Function norm 0.239155
KSP Object: 1 MPI processes
  type: fgmres
    restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization
with no iterative refinement
    happy breakdown tolerance 1e-30
  maximum iterations=10000, initial guess is zero
  tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
  right preconditioning
  using UNPRECONDITIONED norm type for convergence test
PC Object: 1 MPI processes
  type: hypre
    HYPRE BoomerAMG preconditioning
      Cycle type V
      Maximum number of levels 25
      Maximum number of iterations PER hypre call 1
      Convergence tolerance PER hypre call 0.
      Threshold for strong coupling 0.25
      Interpolation truncation factor 0.
      Interpolation: max elements per row 0
      Number of levels of aggressive coarsening 0
      Number of paths for aggressive coarsening 1
      Maximum row sums 0.9
      Sweeps down         1
      Sweeps up           1
      Sweeps on coarse    1
      Relax down          symmetric-SOR/Jacobi
      Relax up            symmetric-SOR/Jacobi
      Relax on coarse     Gaussian-elimination
      Relax weight  (all)      1.
      Outer relax weight (all) 1.
      Using CF-relaxation
      Not using more complex smoothers.
      Measure type        local
      Coarsen type        Falgout
      Interpolation type  classical
  linear system matrix = precond matrix:
  Mat Object: 1 MPI processes
    type: seqaijcusparse
    rows=64, cols=64, bs=4
    total: nonzeros=1024, allocated nonzeros=1024
    total number of mallocs used during MatSetValues calls =0
      using I-node routines: found 16 nodes, limit used is 5
  1 SNES Function norm 6.80716e-05
  type: fgmres
  type: hypre
      Cycle type V
      Sweeps down         1
      Sweeps up           1
      Sweeps on coarse    1
      Using CF-relaxation
      Measure type        local
  2 SNES Function norm 4.093e-11
Number of SNES iterations = 2
On Fri, Nov 2, 2018 at 2:10 PM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> > On Nov 2, 2018, at 1:03 PM, Mark Adams <mfadams at lbl.gov> wrote:
> > FYI, I seem to have the new GPU machine at ORNL (summitdev) working with
> GPUs. That is good enough for now.
> > Thanks,
>    Excellant!
> > 14:00 master= ~/petsc/src/snes/examples/tutorials$ jsrun -n 1 ./ex19
> -dm_vec_type cuda -dm_mat_type aijcusparse -pc_type none -ksp_type fgmres
> >   type: fgmres
> Orthogonalization with no iterative refinement
> >   type: none
> >   1 SNES Function norm 6.82338e-05
> >   type: fgmres
> >   type: none
> >   2 SNES Function norm 3.346e-10
> > 14:01 master= ~/petsc/src/snes/examples/tutorials$
> > On Thu, Nov 1, 2018 at 9:33 AM Mark Adams <mfadams at lbl.gov> wrote:
> > On Wed, Oct 31, 2018 at 12:30 PM Mark Adams <mfadams at lbl.gov> wrote:
> > On Wed, Oct 31, 2018 at 6:59 AM Karl Rupp <rupp at iue.tuwien.ac.at> wrote:
> > Hi Mark,
> > ah, I was confused by the Python information at the beginning of
> > configure.log. So it is picking up the correct compiler.
> > Have you tried uncommenting the check for GNU?
> > Yes, but I am getting an error that the cuda files do not find mpi.h.
> > I'm getting a make error.
> > Thanks,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20181102/33b3a224/attachment-0001.html>
