[petsc-dev] Mat updating from 3.7 to 3.9.2 Fortran
    Jed Brown
    jed at jedbrown.org
    Tue May 22 18:28:08 CDT 2018
Hector E Barrios Molano <hectorb at utexas.edu> writes:
> Hi PETSc Experts!
> I am updating a Fortran code that use PETSc 3.7 to version 3.9.2 (from
> git repository).
> Such code declares:
> Mat mat
> and used it as an integer, for example, to assign an initial value and
> test it to know if the matrix has been created by PETSc.
> data mat/-1/
> if (mat .eq. -1) then
You can use PETSC_NULL_MAT
> With the new PETSc Fortran modules the compiler complains about this and
> stops.
> Is there a better way to achieve this? So that I do not have to set an
> predefined value to Mat type to test if it was already created by PETSc?
> If not, Is there a way to access the value in mat?
> Looking at the source code type(tMat) has "v" variable, so could I used
> as mat%v?
Please no.
