[petsc-dev] Proposed changes to TS API
Emil Constantinescu
emconsta at anl.gov
Fri May 11 15:28:56 CDT 2018
On 5/11/18 3:14 PM, Zhang, Hong wrote:
>> On May 11, 2018, at 1:01 PM, Lisandro Dalcin <dalcinl at gmail.com
>> <mailto:dalcinl at gmail.com>> wrote:
>> On Fri, 11 May 2018 at 19:34, Jed Brown <jed at jedbrown.org
>> <mailto:jed at jedbrown.org>> wrote:
>>> "Smith, Barry F." <bsmith at mcs.anl.gov <mailto:bsmith at mcs.anl.gov>>
>>> writes:
>>>>>> I assemble the combined system directly.
>>>>> How, two sets of calls to MatSetValues(), One for the scaled mass
>> matrix and one for the Jacobian entries? For a constant mass matrix does
>> this mean you are recomputing the mass matrix entries each call? Or
>> are you
>> storing the mass matrix entries somewhere? Or is your mass matrix
>> diagonal
>> only?
>>>> Or do you build element by element the M*shift + J element stiffness
>> and then insert it with a single MatSetValues() call?
>>> It isn't even built separately at the element scale, just summed
>>> contributions at quadrature points.
>> That's exactly the way I do it in PetIGA, and the way I would do it in any
>> other general-purpose FEM-like code. In high-order FEM, Jacobian assembly
>> may very well account from 50% to 80% of runtime (at least that's my
>> experience with PetIGA). IMHO, forcing users to have to do TWO global
>> matrix assemblies per time step is simply unacceptable, both in terms of
>> memory and runtime.
> We are not forcing users to do two matrix assemblies per time step. For
> most cases, there is even no need to update dF/dUdot at all. For extreme
> cases that the application requires frequent update on dF/dUdot and
> assembly is expensive, one can always assemble the single-matrix
> Jacobian and throw it to SNES directly.
>> TS used to be an unusable pile of crap until Jed proposed the marvelous
>> IJacobian interface. Suddenly COMPLEX fully-implicit DAE problems become
>> SIMPLE to express, and a single IFunction/IJacobian pair reusable for
>> different timestepper implementations a reality. And we got an added
>> bounus: this was efficient, it involved a SINGLE global matrix
>> assembly. If
>> the issue is in supporting simpler problems, then we should go for an
>> alternative interface with broken Jacobians, just as Stefano propossed
>> in a
>> previous email. I'm totally in favor of an additional broken Jacobians
>> API,
>> and totally againt the removal of the single-matrix IJacobian interface.
> The current IJacobian is essentially SNESJacobian. And the single-matrix
> SNESJacobian interface is always there. Power users could set up the
> SNESJacobian directly if we pass a read-only shift parameter to them. So
> we are by no means prohibiting power users from doing what they want.
So the plan would be to support both? The problem from the TS type point
of view is that we'd have to support both within all methods if they
co-exist. That would be really painful now (I'm thinking of arkimex,
rosw,...) and much more painful in the future.
Emil
> IJacobian with shift mixes TS Jacobian and SNES Jacobian. This is the
> issue we need to fix.
> Thanks,
> Hong
>> I don't buy the argument that IJacobian with shift is ugly, and that such
>> API drives users away from TS. At best, this is a documentation problem.
>> Come on, this is just chain rule, should be kindergarden-level stuff for
>> PETSc users. If we simplify things for the sake of making things
>> simple for
>> newcomers and beginners and make them annoyingly slow for power users
>> solving complex problems, we will do a very bad business. This is not
>> politically correct, but I'm much worried about loosing power users, you
>> know, those that can eventually make a meaningful contributions to science
>> and software projects. Beginners and newcomers eventually learn and
>> benefit
>> for common-sense software design, and will eventually appreciate it. I
>> really hope populism to not win this battle :-)
>> Lisandro Dalcin
>> Research Scientist
>> Computer, Electrical and Mathematical Sciences & Engineering (CEMSE)
>> Extreme Computing Research Center (ECRC)
>> King Abdullah University of Science and Technology (KAUST)
>> http://ecrc.kaust.edu.sa/
>> 4700 King Abdullah University of Science and Technology
>> al-Khawarizmi Bldg (Bldg 1), Office # 0109
>> Thuwal 23955-6900, Kingdom of Saudi Arabia
>> http://www.kaust.edu.sa <http://www.kaust.edu.sa/>
>> Office Phone: +966 12 808-0459
