[petsc-dev] Proposed changes to TS API
Lisandro Dalcin
dalcinl at gmail.com
Fri May 11 11:05:34 CDT 2018
On Fri, 11 May 2018 at 18:20, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> So you are proposing keeping TSSetIFunction and TSSetIJacobian and
ADDING a new API TSSetComputeSplitJacobians() and it that is not provided
calling TSComputeIJacobian() twice with different shifts (which is
definitely not efficient and is what Hong does also).
Yes, that's basically the proposal. User could even provide both IJacobian
and SplitJacobians, and TS can then make the best use of these callbacks
depending on what is more efficient.
Lisandro Dalcin
Research Scientist
Computer, Electrical and Mathematical Sciences & Engineering (CEMSE)
Extreme Computing Research Center (ECRC)
King Abdullah University of Science and Technology (KAUST)
http://ecrc.kaust.edu.sa/
4700 King Abdullah University of Science and Technology
al-Khawarizmi Bldg (Bldg 1), Office # 0109
Thuwal 23955-6900, Kingdom of Saudi Arabia
http://www.kaust.edu.sa
Office Phone: +966 12 808-0459
