[petsc-dev] calling petsc from a mex file
Munson, Todd
tmunson at mcs.anl.gov
Tue May 8 14:30:05 CDT 2018
Its in tmunson/tao-pounders-matlab-interface
Most of the code is commented out or otherwise inactive. There is a hacked
command in src/tao/leastsquares/examples/matlab that I use to compile the
mex file.
To test, you should be able to start matlab and say "taopounders(); exit".
Todd.
> On May 8, 2018, at 2:21 PM, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> Push the branch that does this or send me the code and I'll debug it. I now have some vague memory about this behavior.
> Barry
>> On May 8, 2018, at 1:53 PM, Munson, Todd <tmunson at mcs.anl.gov> wrote:
>>> On May 8, 2018, at 1:02 PM, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>>>> On May 8, 2018, at 12:30 PM, Munson, Todd <tmunson at mcs.anl.gov> wrote:
>>>> Hi,
>>>> I wonder if anyone has experience calling petsc from matlab using mex. I have the
>>>> simplest possible mexFunction that just calls PetscInitialize() and
>>>> PetscFinalize(). That part seems to work fine, but when I exit
>>>> from matlab I get a segmentation violation and a petsc error
>>>> message.
>>> What are all the error messages? Cut and paste. I've done this in the past but not for years.
>> Below is the matlab session and error message. I do note that if I issue PetscFinalize() and
>> that command completes, the Petsc signal handlers remain installed/active. If I do a
>> PetscPopSignalHandler() immediately after PetscInitialize(), I do not get the error
>> message, but a "Segmentation fault: 11" output at the end.
>> Because petsc is being loaded as a dynamic library, are there possibly uninitialized global
>> variables or state?
>> Thanks, Todd.
>> [0]PETSC ERROR: ------------------------------------------------------------------------
>> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
>> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>> [0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
>> [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
>> [0]PETSC ERROR: likely location of problem given in stack below
>> [0]PETSC ERROR: --------------------- Stack Frames ------------------------------------
>> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
>> [0]PETSC ERROR: INSTEAD the line number of the start of the function
>> [0]PETSC ERROR: is given.
>> [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
>> [0]PETSC ERROR: Signal received
>> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
>> [0]PETSC ERROR: Petsc Development GIT revision: v3.9.1-409-gf553c6556e GIT Date: 2018-05-07 17:17:17 -0500
>> [0]PETSC ERROR: Unknown Name on a arch-darwin-c-debug named eduroam062-089.wl.anl-external.org by tmunson Tue May 8 12:04:45 2018
>> [0]PETSC ERROR: Configure options --download-mpich CC=/usr/bin/clang CXX=/usr/bin/clang++ FC=/opt/local/bin/gfortran
>> [0]PETSC ERROR: #1 User provided function() line 0 in unknown file
>> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
>> [unset]: write_line error; fd=-1 buf=:cmd=abort exitcode=59
>> system msg for write_line failure : Bad file descriptor
