[petsc-dev] GCC8 Fortran length changes from int to size_t
Lisandro Dalcin
dalcinl at gmail.com
Mon May 7 03:56:44 CDT 2018
On Mon, 7 May 2018 at 03:11, Jed Brown <jed at jedbrown.org> wrote:
> Lisandro Dalcin <dalcinl at gmail.com> writes:
> >> > How do you exactly want to implement that? Totally replace these
> >> > special functions with the BIND(C) interface that calls directly the
C
> >> > function, or rather generate a native Fortran subroutine that calls
> >> > the C function through a BIND(C) interface?
> >> The latter. Usage should not change for existing Fortran users.
> > Things may end up being involved anyway, even if using ISO_C_BINDINGS.
> > http://fortranwiki.org/fortran/show/Generating+C+Interfaces#strings
> I guess I don't understand. Are you concerned about the string copying?
> Note that FIXCHAR (used in current interfaces) allocates memory.
Well, no, my point is that an automatic interface generator based on
ISO_C_BINDINGS (as Barry wanted) may prove slightly harder to implement
than expected.
Lisandro Dalcin
Research Scientist
Computer, Electrical and Mathematical Sciences & Engineering (CEMSE)
Extreme Computing Research Center (ECRC)
King Abdullah University of Science and Technology (KAUST)
http://ecrc.kaust.edu.sa/
4700 King Abdullah University of Science and Technology
al-Khawarizmi Bldg (Bldg 1), Office # 0109
Thuwal 23955-6900, Kingdom of Saudi Arabia
http://www.kaust.edu.sa
Office Phone: +966 12 808-0459
