[petsc-dev] GCC8 Fortran length changes from int to size_t
    Jed Brown
    jed at jedbrown.org
    Wed May  2 11:15:34 CDT 2018
Lisandro Dalcin <dalcinl at gmail.com> writes:
> On Wed, 2 May 2018 at 17:29, Satish Balay <balay at mcs.anl.gov> wrote:
>> So we need a 64bit arm with gcc8 - for this testcase failure?
> Or a big-endian machine/OS ?
Shouldn't be necessary, but why are we so concerned about making a test
case fail instead of implementing correct behavior?
