[petsc-dev] [PETSc-3.8.4] src/mat/impls/hypre/mhypre.c compilation failed
    Satish Balay
    balay at mcs.anl.gov
    Fri Mar 30 10:07:30 CDT 2018
current petsc code is tested with hypre-v2.12.0.
So this must be due to changes in hypre-v2.14.0.
Ok looks like we need the following change - but this update is likely
to go into 3.9 [and not 3.8 - which we hope to release next week]
Satish
commit e6de09342ce9c4562cc062ff2c1bac4bd956bda0 (HEAD -> balay/update-hypre-v2.14.0)
Author: Satish Balay <balay at mcs.anl.gov>
Date:   Fri Mar 30 09:53:12 2018 -0500
    hypre: update to version 2.14.0
    Reported-by: Antonio Trande <anto.trande at gmail.com>
diff --git a/config/BuildSystem/config/packages/hypre.py b/config/BuildSystem/config/packages/hypre.py
index 1249b39374..620e51602a 100644
--- a/config/BuildSystem/config/packages/hypre.py
+++ b/config/BuildSystem/config/packages/hypre.py
@@ -4,7 +4,7 @@ import os
 class Configure(config.package.GNUPackage):
   def __init__(self, framework):
     config.package.GNUPackage.__init__(self, framework)
-    self.gitcommit = 'v2.12.0'
+    self.gitcommit = 'v2.14.0'
     self.download  = ['git://https://github.com/LLNL/hypre','https://github.com/LLNL/hypre/archive/'+self.gitcommit+'.tar.gz']
     self.functions = ['HYPRE_IJMatrixCreate']
     self.includes  = ['HYPRE.h']
diff --git a/src/mat/impls/hypre/mhypre.c b/src/mat/impls/hypre/mhypre.c
index 8a51581a09..65595f2af4 100644
--- a/src/mat/impls/hypre/mhypre.c
+++ b/src/mat/impls/hypre/mhypre.c
@@ -1450,6 +1450,6 @@ PETSC_EXTERN PetscErrorCode MatCreate_HYPRE(Mat B)
 static PetscErrorCode hypre_array_destroy(void *ptr)
    PetscFunctionBegin;
-   hypre_TFree(ptr);
+   hypre_TFree(ptr,HYPRE_MEMORY_HOST);
    PetscFunctionReturn(0);
On Fri, 30 Mar 2018, Antonio Trande wrote:
> Hello everyone.
> 'src/mat/impls/hypre/mhypre.c' file compilation is failed (full log [1])
> with this error:
> mpicc -c -O2 -g -pipe -Wall -Werror=format-security
> -Wp,-D_FORTIFY_SOURCE=2 -Wp,-D_GLIBCXX_ASSERTIONS -fexceptions
> -fstack-protector-strong -grecord-gcc-switches
> -specs=/usr/lib/rpm/redhat/redhat-annobin-cc1 -m64 -mtune=generic
> -fasynchronous-unwind-tables -fstack-clash-protection -mcet
> -fcf-protection -O3 -Wl,-z,now -fPIC
> -I/builddir/build/BUILD/petsc-3.8.4/buildopenmpi_dir/include
> -I/builddir/build/BUILD/petsc-3.8.4/buildopenmpi_dir/x86_64/include
> -I/usr/include/openmpi-x86_64/hypre -I/usr/include/openmpi-x86_64
> -MMD -MP
> /builddir/build/BUILD/petsc-3.8.4/buildopenmpi_dir/src/mat/impls/hypre/mhypre.c
> -o x86_64/obj/src/mat/impls/hypre/mhypre.o
> /builddir/build/BUILD/petsc-3.8.4/buildopenmpi_dir/src/mat/impls/hypre/mhypre.c:
> In function 'hypre_array_destroy':
> /builddir/build/BUILD/petsc-3.8.4/buildopenmpi_dir/src/mat/impls/hypre/mhypre.c:1453:19:
> error: macro "hypre_TFree" requires 2 arguments, but only 1 given
>     hypre_TFree(ptr);
> /builddir/build/BUILD/petsc-3.8.4/buildopenmpi_dir/src/mat/impls/hypre/mhypre.c:1453:4:
> error: 'hypre_TFree' undeclared (first use in this function); did you
> mean 'hypre_Free'?
>     hypre_TFree(ptr);
>     hypre_Free
> note: each undeclared identifier is reported only once for each function
> it appears in
> gmake[2]: *** [gmakefile:227: x86_64/obj/src/mat/impls/hypre/mhypre.o]
> Error 1
> Please, take a look.
> [1] https://kojipkgs.fedoraproject.org//work/tasks/6330/26056330/build.log
> System: Fedora 29 (devel branch)
> GCC 8.0.1
> OpenMPI 2.1.1
> Hypre 2.14.0
