[petsc-dev] Fwd: [mpich-discuss] Is mpich/master:a8a2b30fd21 tested with Petsc?
Matthew Knepley
knepley at gmail.com
Tue Mar 27 16:06:39 CDT 2018
You are kidding me.
Matt
---------- Forwarded message ----------
Date: Tue, Mar 27, 2018 at 5:05 PM
Subject: Re: [petsc-dev] [mpich-discuss] Is mpich/master:a8a2b30fd21 tested
with Petsc?
To: knepley at gmail.com
You are not allowed to post to this mailing list because your email
address is not subscribed. Therefore, your message has been
automatically rejected. If you wish to subscribe to this list, please
do so at:
https://lists.mpich.org/mailman/listinfo/discuss
If you think that your messages are being rejected in error, please
check that you are using the correct email address when sending
messages, then contact the mailing list owner at
discuss-owner at lists.mpich.org.
To: Min Si <msi at anl.gov>
Cc: discuss at mpich.org, PETSc <petsc-dev at mcs.anl.gov>
Bcc:
Date: Tue, 27 Mar 2018 17:04:57 -0400
with Petsc?
On Tue, Mar 27, 2018 at 4:59 PM, Min Si <msi at anl.gov> wrote:
> Hi Eric,
> It will be great if you could give us a simple MPI program (not with
> PETSc) to reproduce this issue. If this is a problem happens only when
> PETSc is involved, the PETSc team can give you more suggestions.
Hi Min,
It is really easy to run PETSc at ANL. I am sure one of us can help if you
cannot reproduce this bug on your own.
Matt
> Thanks,
> Min
> On 2018/03/27 15:38, Eric Chamberland wrote:
>> Hi,
>> since more than 2 weeks that the master branch of mpich is still and it
>> can be reproduced with a simple "make test" after a fresh installation of
>> PETSc...
>> Is anyone testing it?
>> Is it supposed to be working?
>> Just tell me if I should "follow" another mpich branch please.
>> Thanks,
>> Eric
>> On 14/03/18 03:35 AM, Eric Chamberland wrote:
>>> Hi,
>>> fwiw, the actual mpich/master branch doesn't passes the PETSc "make
>>> test" after a fresh installation... It hangs just afer the 1 MPI process
>>> test, meaning it is locked into the 2 process test:
>>> make PETSC_DIR=/pmi/cmpbib/compilation_BIB_dernier_mpich/COMPILE_
>>> AUTO/mpich-3.x-debug/petsc-3.8.3-debug PETSC_ARCH=arch-linux2-c-debug
>>> test
>>> Running test examples to verify correct installation
>>> Using PETSC_DIR=/pmi/cmpbib/compilation_BIB_dernier_mpich/COMPILE_
>>> AUTO/mpich-3.x-debug/petsc-3.8.3-debug and
>>> C/C++ example src/snes/examples/tutorials/ex19 run successfully with 1
>>> MPI process
>>> ^Cmakefile:151: recipe for target 'test' failed
>>> make: [test] Interrupt (ignored)
>>> thanks,
>>> Eric
>>> On 13/03/18 08:07 AM, Eric Chamberland wrote:
>>>> Hi,
>>>> each night we are testing mpich/master with our petsc-based code. I
>>>> don't know if PETSc team is doing the same thing with mpich/master?
>>>> (Maybe it is a good idea?)
>>>> Everything was fine (except the issue https://github.com/pmodels/mpi
>>>> ch/issues/2892) up to commit 7b8d64debd, but since commit
>>>> mpich:a8a2b30fd21), I have a segfault on a any parallel nightly test.
>>>> For example, a 2 process test ends at almost different execution points:
>>>> rank 0:
>>>> #003: /lib64/libpthread.so.0(+0xf870) [0x7f25bf908870]
>>>> #004: /pmi/cmpbib/compilation_BIB_dernier_mpich/COMPILE_AUTO/BIB/bin/BIBMEFGD.opt()
>>>> [0x64a788]
>>>> #005: /lib64/libc.so.6(+0x35140) [0x7f25bca18140]
>>>> #006: /lib64/libc.so.6(__poll+0x2d) [0x7f25bcabfbfd]
>>>> #007: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x1e4cc9) [0x7f25bd90ccc9]
>>>> #008: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x1ea55c) [0x7f25bd91255c]
>>>> #009: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0xba657) [0x7f25bd7e2657]
>>>> #010: /opt/mpich-3.x_debug/lib/libmpi.so.0(PMPI_Waitall+0xe3)
>>>> [0x7f25bd7e3343]
>>>> #011: /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(P
>>>> etscGatherMessageLengths+0x654) [0x7f25c4bb3193]
>>>> #012: /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(VecScatterCreate_PtoS+0x859)
>>>> [0x7f25c4e82d7f]
>>>> #013: /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(VecScatterCreate+0x5684)
>>>> [0x7f25c4e4d055]
>>>> #014: /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(VecCreateGhostWithArray+0x688)
>>>> [0x7f25c4e01a39]
>>>> #015: /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(VecCreateGhost+0x179)
>>>> [0x7f25c4e020f6]
>>>> rank 1:
>>>> #002: /pmi/cmpbib/compilation_BIB_dernier_mpich/COMPILE_AUTO/GIREF
>>>> /lib/libgiref_opt_Util.so(traitementSignal+0x2bd0) [0x7f62df8e7310]
>>>> #003: /lib64/libc.so.6(+0x35140) [0x7f62d3bc9140]
>>>> #004: /lib64/libc.so.6(__poll+0x2d) [0x7f62d3c70bfd]
>>>> #005: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x1e4cc9) [0x7f62d4abdcc9]
>>>> #006: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x1ea55c) [0x7f62d4ac355c]
>>>> #007: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x12c9c5) [0x7f62d4a059c5]
>>>> #008: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x12e102) [0x7f62d4a07102]
>>>> #009: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0xf17a1) [0x7f62d49ca7a1]
>>>> #010: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x3facf) [0x7f62d4918acf]
>>>> #011: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x3fc3d) [0x7f62d4918c3d]
>>>> #012: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0xf18d8) [0x7f62d49ca8d8]
>>>> #013: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x3fb88) [0x7f62d4918b88]
>>>> #014: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x3fc3d) [0x7f62d4918c3d]
>>>> #015: /opt/mpich-3.x_debug/lib/libmpi.so.0(MPI_Barrier+0x27b)
>>>> [0x7f62d4918edb]
>>>> #016: /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(PetscCommGetNewTag+0x3ff)
>>>> [0x7f62dbceb055]
>>>> #017: /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(PetscObjectGetNewTag+0x15d)
>>>> [0x7f62dbceaadb]
>>>> #018: /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(V
>>>> ecScatterCreateCommon_PtoS+0x1ee) [0x7f62dc03625c]
>>>> #019: /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(VecScatterCreate_PtoS+0x29c4)
>>>> [0x7f62dc035eea]
>>>> #020: /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(VecScatterCreate+0x5684)
>>>> [0x7f62dbffe055]
>>>> #021: /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(VecCreateGhostWithArray+0x688)
>>>> [0x7f62dbfb2a39]
>>>> #022: /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(VecCreateGhost+0x179)
>>>> [0x7f62dbfb30f6]
>>>> Have some other users (PETSc users?) reported problem?
>>>> Thanks,
>>>> Eric
>>>> ps: usual informations:
>>>> mpich logs:
>>>> http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.1
>>>> 2.05h39m54s_config.log
>>>> 2.05h39m54s_config.system
>>>> 2.05h39m54s_mpich_version.txt
>>>> 2.05h39m54s_c.txt
>>>> 2.05h39m54s_m.txt
>>>> 2.05h39m54s_mi.txt
>>>> 2.05h39m54s_openmpa_config.log
>>>> 2.05h39m54s_mpl_config.log
>>>> 2.05h39m54s_pm_hydra_config.log
>>>> 2.05h39m54s_pm_hydra_tools_topo_config.log
>>>> 2.05h39m54s_mpiexec_info.txt
>>>> Petsc logs:
>>>> 2.05h39m54s_configure.log
>>>> 2.05h39m54s_make.log
>>>> 2.05h39m54s_default.log
>>>> 2.05h39m54s_RDict.log
>>>> 2.05h39m54s_CMakeLists.txt
>>> _______________________________________________
>> discuss mailing list discuss at mpich.org
>> To manage subscription options or unsubscribe:
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180327/c697bdce/attachment.html>
