[petsc-dev] [mpich-discuss] Is mpich/master:a8a2b30fd21 tested with Petsc?
Min Si
msi at anl.gov
Tue Mar 27 15:59:26 CDT 2018
Hi Eric,
It will be great if you could give us a simple MPI program (not with
PETSc) to reproduce this issue. If this is a problem happens only when
PETSc is involved, the PETSc team can give you more suggestions.
Min
On 2018/03/27 15:38, Eric Chamberland wrote:
> Hi,
> since more than 2 weeks that the master branch of mpich is still and
> it can be reproduced with a simple "make test" after a fresh
> installation of PETSc...
> Is anyone testing it?
> Is it supposed to be working?
> Just tell me if I should "follow" another mpich branch please.
> Thanks,
> Eric
> On 14/03/18 03:35 AM, Eric Chamberland wrote:
>> Hi,
>> fwiw, the actual mpich/master branch doesn't passes the PETSc "make
>> test" after a fresh installation... It hangs just afer the 1 MPI
>> process test, meaning it is locked into the 2 process test:
>> make
>> PETSC_DIR=/pmi/cmpbib/compilation_BIB_dernier_mpich/COMPILE_AUTO/mpich-3.x-debug/petsc-3.8.3-debug
>> PETSC_ARCH=arch-linux2-c-debug test
>> Running test examples to verify correct installation
>> Using
>> and PETSC_ARCH=arch-linux2-c-debug
>> C/C++ example src/snes/examples/tutorials/ex19 run successfully with
>> 1 MPI process
>> ^Cmakefile:151: recipe for target 'test' failed
>> make: [test] Interrupt (ignored)
>> thanks,
>> Eric
>> On 13/03/18 08:07 AM, Eric Chamberland wrote:
>>> Hi,
>>> each night we are testing mpich/master with our petsc-based code. I
>>> don't know if PETSc team is doing the same thing with
>>> mpich/master? (Maybe it is a good idea?)
>>> Everything was fine (except the issue
>>> https://github.com/pmodels/mpich/issues/2892) up to commit
>>> 7b8d64debd, but since commit mpich:a8a2b30fd21), I have a segfault
>>> on a any parallel nightly test.
>>> For example, a 2 process test ends at almost different execution
>>> points:
>>> rank 0:
>>> #003: /lib64/libpthread.so.0(+0xf870) [0x7f25bf908870]
>>> #004:
>>> /pmi/cmpbib/compilation_BIB_dernier_mpich/COMPILE_AUTO/BIB/bin/BIBMEFGD.opt()
>>> [0x64a788]
>>> #005: /lib64/libc.so.6(+0x35140) [0x7f25bca18140]
>>> #006: /lib64/libc.so.6(__poll+0x2d) [0x7f25bcabfbfd]
>>> #007: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x1e4cc9) [0x7f25bd90ccc9]
>>> #008: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x1ea55c) [0x7f25bd91255c]
>>> #009: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0xba657) [0x7f25bd7e2657]
>>> #010: /opt/mpich-3.x_debug/lib/libmpi.so.0(PMPI_Waitall+0xe3)
>>> [0x7f25bd7e3343]
>>> #011:
>>> /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(PetscGatherMessageLengths+0x654)
>>> [0x7f25c4bb3193]
>>> #012:
>>> /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(VecScatterCreate_PtoS+0x859)
>>> [0x7f25c4e82d7f]
>>> #013:
>>> /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(VecScatterCreate+0x5684)
>>> [0x7f25c4e4d055]
>>> #014:
>>> /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(VecCreateGhostWithArray+0x688)
>>> [0x7f25c4e01a39]
>>> #015:
>>> /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(VecCreateGhost+0x179)
>>> [0x7f25c4e020f6]
>>> rank 1:
>>> #002:
>>> /pmi/cmpbib/compilation_BIB_dernier_mpich/COMPILE_AUTO/GIREF/lib/libgiref_opt_Util.so(traitementSignal+0x2bd0)
>>> [0x7f62df8e7310]
>>> #003: /lib64/libc.so.6(+0x35140) [0x7f62d3bc9140]
>>> #004: /lib64/libc.so.6(__poll+0x2d) [0x7f62d3c70bfd]
>>> #005: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x1e4cc9) [0x7f62d4abdcc9]
>>> #006: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x1ea55c) [0x7f62d4ac355c]
>>> #007: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x12c9c5) [0x7f62d4a059c5]
>>> #008: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x12e102) [0x7f62d4a07102]
>>> #009: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0xf17a1) [0x7f62d49ca7a1]
>>> #010: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x3facf) [0x7f62d4918acf]
>>> #011: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x3fc3d) [0x7f62d4918c3d]
>>> #012: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0xf18d8) [0x7f62d49ca8d8]
>>> #013: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x3fb88) [0x7f62d4918b88]
>>> #014: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x3fc3d) [0x7f62d4918c3d]
>>> #015: /opt/mpich-3.x_debug/lib/libmpi.so.0(MPI_Barrier+0x27b)
>>> [0x7f62d4918edb]
>>> #016:
>>> /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(PetscCommGetNewTag+0x3ff)
>>> [0x7f62dbceb055]
>>> #017:
>>> /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(PetscObjectGetNewTag+0x15d)
>>> [0x7f62dbceaadb]
>>> #018:
>>> /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(VecScatterCreateCommon_PtoS+0x1ee)
>>> [0x7f62dc03625c]
>>> #019:
>>> /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(VecScatterCreate_PtoS+0x29c4)
>>> [0x7f62dc035eea]
>>> #020:
>>> [0x7f62dbffe055]
>>> #021:
>>> [0x7f62dbfb2a39]
>>> #022:
>>> [0x7f62dbfb30f6]
>>> Have some other users (PETSc users?) reported problem?
>>> Thanks,
>>> Eric
>>> ps: usual informations:
>>> mpich logs:
>>> http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_config.log
>>> http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_config.system
>>> http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_mpich_version.txt
>>> http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_c.txt
>>> http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_m.txt
>>> http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_mi.txt
>>> http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_openmpa_config.log
>>> http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_mpl_config.log
>>> http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_pm_hydra_config.log
>>> http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_pm_hydra_tools_topo_config.log
>>> http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_mpiexec_info.txt
>>> Petsc logs:
>>> http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_configure.log
>>> http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_make.log
>>> http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_default.log
>>> http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_RDict.log
>>> http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_CMakeLists.txt
> discuss mailing list discuss at mpich.org
> To manage subscription options or unsubscribe:
> https://lists.mpich.org/mailman/listinfo/discuss
