[petsc-dev] Manual builds fail on master
    Smith, Barry F.
    bsmith at mcs.anl.gov
    Thu Mar 22 11:18:18 CDT 2018
  Satish,
   Where did you find this error message on the web? I couldn't find any building of the manual from the Dashboard.
> On Mar 22, 2018, at 11:05 AM, Balay, Satish <balay at mcs.anl.gov> wrote:
> petsc at thwomp:/sandbox/petsc/petsc.clone/src/docs/tex/manual$ /usr/bin/make  --no-print-directory manual.pdf LOC=/sandbox/petsc/petsc.clone GONULL=
> <snip>
> aTeX Warning: Reference `ch_index' on page 7 undefined on input line 42.
> ) [7] [8] (./acknowltmp.tex
> ! You can't use `macro parameter character #' in horizontal mode.
> l.1 ...++man+manualpages/Mat/MatMPIAdjToSeq-.html#
>                                                  MatMPIAdjToSeq-
> !  ==> Fatal error occurred, no output PDF file produced!
> Transcript written on manual1.log.
> make: *** [manual.pdf] Error 1
> Perhaps the following fix:
> diff --git a/src/mat/impls/adj/mpi/mpiadj.c b/src/mat/impls/adj/mpi/mpiadj.c
> index 5241a8fae9..e8425726d9 100644
> --- a/src/mat/impls/adj/mpi/mpiadj.c
> +++ b/src/mat/impls/adj/mpi/mpiadj.c
> @@ -806,7 +806,7 @@ PETSC_EXTERN PetscErrorCode MatCreate_MPIAdj(Mat B)
> /*@C
> -   MatMPIAdjToSeq- Converts an parallel MPIAdj matrix to complete MPIAdj on each process (needed by sequential preconditioners)
> +   MatMPIAdjToSeq - Converts an parallel MPIAdj matrix to complete MPIAdj on each process (needed by sequential preconditioners)
>    Logically Collective on MPI_Comm
> Will check if this works..
> Satish
> On Thu, 22 Mar 2018, Smith, Barry F. wrote:
>>   I'll talk to Satish, it is now unclear (at least to me) where the manual is actually built and the output stored.
>>> On Mar 22, 2018, at 5:17 AM, Patrick Sanan <patrick.sanan at gmail.com> wrote:
>>> The manual and dev manual automated builds are failing on master, but I can't reproduce on any of my local builds and the output is now very terse, so it's not obvious to me how to debug. There were some updates recently to the manual make process, which could be related.
>>> I'd move to re-introduce more of the tex output by default when building the manuals - this clutters the log but overall I'd say would save time (and might be the most efficient way to debug this current issue).
