[petsc-dev] Manual builds fail on master
    Patrick Sanan
    patrick.sanan at gmail.com
    Thu Mar 22 11:16:25 CDT 2018
Thanks! I should have caught this myself by rebuilding all my local docs
instead of just the manual.
2018-03-22 17:05 GMT+01:00 Satish Balay <balay at mcs.anl.gov>:
> petsc at thwomp:/sandbox/petsc/petsc.clone/src/docs/tex/manual$
> /usr/bin/make  --no-print-directory manual.pdf
> LOC=/sandbox/petsc/petsc.clone GONULL=
> <snip>
> aTeX Warning: Reference `ch_index' on page 7 undefined on input line 42.
> ) [7] [8] (./acknowltmp.tex
> ! You can't use `macro parameter character #' in horizontal mode.
> l.1 ...++man+manualpages/Mat/MatMPIAdjToSeq-.html#
>                                                   MatMPIAdjToSeq-
> !  ==> Fatal error occurred, no output PDF file produced!
> Transcript written on manual1.log.
> make: *** [manual.pdf] Error 1
> Perhaps the following fix:
> diff --git a/src/mat/impls/adj/mpi/mpiadj.c b/src/mat/impls/adj/mpi/
> mpiadj.c
> index 5241a8fae9..e8425726d9 100644
> --- a/src/mat/impls/adj/mpi/mpiadj.c
> +++ b/src/mat/impls/adj/mpi/mpiadj.c
> @@ -806,7 +806,7 @@ PETSC_EXTERN PetscErrorCode MatCreate_MPIAdj(Mat B)
>  /*@C
> -   MatMPIAdjToSeq- Converts an parallel MPIAdj matrix to complete MPIAdj
> on each process (needed by sequential preconditioners)
> +   MatMPIAdjToSeq - Converts an parallel MPIAdj matrix to complete MPIAdj
>     Logically Collective on MPI_Comm
> Will check if this works..
> Satish
> On Thu, 22 Mar 2018, Smith, Barry F. wrote:
> >    I'll talk to Satish, it is now unclear (at least to me) where the
> manual is actually built and the output stored.
> > > On Mar 22, 2018, at 5:17 AM, Patrick Sanan <patrick.sanan at gmail.com>
> wrote:
> > > The manual and dev manual automated builds are failing on master, but
> I can't reproduce on any of my local builds and the output is now very
> terse, so it's not obvious to me how to debug. There were some updates
> recently to the manual make process, which could be related.
> > > I'd move to re-introduce more of the tex output by default when
> building the manuals - this clutters the log but overall I'd say would save
> time (and might be the most efficient way to debug this current issue).
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180322/de4bf327/attachment-0001.html>
