[petsc-dev] --prefix install totally broken in next on Mac
Smith, Barry F. bsmith at mcs.anl.gov
Wed Mar 21 19:18:08 CDT 2018
After a make install
otool -L petsc-install/lib/libpetsc.dylib
petsc-install/lib/libpetsc.dylib:
        arch-simp/lib/libpetsc.3.08.dylib (compatibility version 3.8.0, current version 3.8.3)
        /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib (compatibility version 1.0.0, current version 1.0.0)
        /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib (compatibility version 1.0.0, current version 1.0.0)
        /Users/barrysmith/Src/petsc/arch-simp/externalpackages/git.saws/build/lib/libSAWs.so (compatibility version 0.0.0, current version 0.0.0)
        /opt/X11/lib/libX11.6.dylib (compatibility version 10.0.0, current version 10.0.0)
        /usr/lib/libc++.1.dylib (compatibility version 1.0.0, current version 400.9.0)
        /usr/lib/libSystem.B.dylib (compatibility version 1.0.0, current version 1252.0.0)
        /usr/local/opt/mpich/lib/libmpifort.12.dylib (compatibility version 14.0.0, current version 14.0.0)
        /usr/local/opt/mpich/lib/libmpi.12.dylib (compatibility version 14.0.0, current version 14.0.0)
        /usr/local/opt/mpich/lib/libpmpi.12.dylib (compatibility version 14.0.0, current version 14.0.0)
        /usr/local/opt/gcc/lib/gcc/7/libgfortran.4.dylib (compatibility version 5.0.0, current version 5.0.0)
        /usr/local/lib/gcc/7/libgcc_s.1.dylib (compatibility version 1.0.0, current version 1.0.0)
        /usr/local/opt/gcc/lib/gcc/7/libquadmath.0.dylib (compatibility version 1.0.0, current version 1.0.0)
        /usr/local/opt/mpich/lib/libmpicxx.12.dylib (compatibility version 14.0.0, current version 14.0.0)
It has the wrong location for PETSc library and for Saws library
>From configure.log is one problem
PETSC_WITH_EXTERNAL_LIB = -L/Users/barrysmith/Src/petsc/arch-simp/lib -Wl,-rpath,/Users/barrysmith/Src/petsc/petsc-install/lib -L/Users/barrysmith/Src/petsc/petsc-install/lib -Wl,-rpath,/opt/X11/lib -L/opt/X11/lib -Wl,-rpath,/usr/local/Cellar/mpich/3.2_3/lib -L/usr/local/Cellar/mpich/3.2_3/lib -Wl,-rpath,/usr/local/Cellar/gcc/7.3.0_1/lib/gcc/7/gcc/x86_64-apple-darwin17.3.0/7.3.0 -L/usr/local/Cellar/gcc/7.3.0_1/lib/gcc/7/gcc/x86_64-apple-darwin17.3.0/7.3.0 -Wl,-rpath,/usr/local/Cellar/gcc/7.3.0_1/lib/gcc/7 -L/usr/local/Cellar/gcc/7.3.0_1/lib/gcc/7 -Wl,-rpath,/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/9.0.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/9.0.0/lib/darwin -lpetsc -llapack -lblas -lSAWs -lX11 -lstdc++ -ldl -lmpifort -lmpi -lpmpi -lgfortran -lSystem -lgcc_ext.10.5 -lquadmath -lm -lc++ -ldl -lmpicxx -lmpi -lpmpi -lSystem -lclang_rt.osx -lstdc++ -ldl
starts with /Users/barrysmith/Src/petsc/arch-simp/lib which I would think it problematic.
If there is not one yet there needs to be a prefix install for Mac in the nightlies
make gnumake VERBOSE=1 does not show how the library is built, how does one see what exactly is being passed to build the library? Impossible for me to debug.
This was all fine in the past for prefix builds on the Mac all the recent messing around broke it.
   Barry
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180322/4c559f88/attachment-0001.html>
Desc: configure.log
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180322/4c559f88/attachment-0002.obj>
Desc: petscvariables
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180322/4c559f88/attachment-0003.obj>
