[petsc-dev] Nested event logging and human friendly output
Smith, Barry F. bsmith at mcs.anl.gov
Wed Mar 21 11:17:51 CDT 2018
  Try this https:    //bitbucket.org/     petsc/petsc/commits/607d249ec66f5be42ddd7f6f35ea64c82fd126db   remove the spaces from the URL
> On Mar 21, 2018, at 3:58 AM, Koos Huijssen <koos.huijssen at vortech.nl> wrote:
> Hi Barry,
> I couldn't gain access to the pull request. I have reconfigured by bitbucket account, could you try this again?
> Regards
> From: Smith, Barry F. <bsmith at mcs.anl.gov>
> Sent: Tuesday, March 20, 2018 16:31
> To: Koos Huijssen
> Cc: Klaij, Christiaan; petsc-dev at mcs.anl.gov
> Subject: Re: [petsc-dev] Nested event logging and human friendly output
>   How does https://emea01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fbitbucket.org%2Fpetsc%2Fpetsc%2Fpull-requests%2Fnew%3Fsource%3Dbarry%2Fdocs-for-nested-xml-log-view%26t%3D1&data=02%7C01%7Ckoos.huijssen%40vortech.nl%7C89ab8f1c6cf3429820c508d58e77af22%7C5fe8f8070fe44cdf8dc636475a0b8555%7C0%7C1%7C636571567074241616&sdata=YM86JOK2As2wRQJhTurtpm4z7u8VbqMkQ9L49It57cE%3D&reserved=0  look?
>    Thanks
>    Barry
> > On Mar 20, 2018, at 4:40 AM, Koos Huijssen <koos.huijssen at vortech.nl> wrote:
> > Dear Barry, Chris,
> > In that case in my opinion the best strategy would be to
> > 1) Not have a full path in the stylesheet line of the xml output, so just use the line
> >        <?xml-stylesheet type="text/xsl" href="performance_xml2html.xsl"?>
> > 2) Have a note in the manual that
> >        - Instructs the user to copy the style sheet next to the xml output file.
> >        - Explains that with this setup the user should be able to view the reports using Firefox and Internet Explorer. For Chrome the option --allow-file-access-from-files should be set. For Safari, local file access should also be enabled (see https://emea01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fccm.net%2Ffaq%2F36342-safari-how-to-enable-local-file-access&data=02%7C01%7Ckoos.huijssen%40vortech.nl%7C89ab8f1c6cf3429820c508d58e77af22%7C5fe8f8070fe44cdf8dc636475a0b8555%7C0%7C1%7C636571567074241616&sdata=wduvj5zczvFX%2FnxDH0kD%2B4Idl9M2Kmnv9jK2WOL84Kk%3D&reserved=0)
> >        - As a fall-back the user can also transform the xml to html using the linux tool 'xsltproc' (see https://emea01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fxmlsoft.org%2FXSLT%2Fxsltproc2.html&data=02%7C01%7Ckoos.huijssen%40vortech.nl%7C89ab8f1c6cf3429820c508d58e77af22%7C5fe8f8070fe44cdf8dc636475a0b8555%7C0%7C1%7C636571567074241616&sdata=uud8nC7aTR9t8A47uALmb%2FkQC7Mgsf3HUUwM2hJKyzM%3D&reserved=0)
> > I have tested Firefox, IE, Chrome and Safari on our systems using the above procedure (Windows: IE, Firefox and Chrome, Linux: Firefox, IOS: Safari) an it works well. Previously I also tested xsltproc, and this also works.
> > If you wouldn't like this approach then we could also experiment with embedding the stylesheet into the xml, see https://emea01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.dpawson.co.uk%2Fxsl%2Fsect2%2Fonefile.html&data=02%7C01%7Ckoos.huijssen%40vortech.nl%7C89ab8f1c6cf3429820c508d58e77af22%7C5fe8f8070fe44cdf8dc636475a0b8555%7C0%7C1%7C636571567074241616&sdata=ZwKnULhzOVkgVve%2BgFihmwWObERIcL%2Flhgx%2FsXMzIwY%3D&reserved=0. But I currently do not have the resources to do that.
> > With kind regards,
> > Koos
> > -----Original Message-----
> > From: Smith, Barry F. [mailto:bsmith at mcs.anl.gov]
> > Sent: vrijdag 16 maart 2018 19:55
> > To: Koos Huijssen <koos.huijssen at vortech.nl>
> > Cc: Klaij, Christiaan <C.Klaij at marin.nl>; petsc-dev at mcs.anl.gov
> >> On Mar 16, 2018, at 6:06 AM, Koos Huijssen <koos.huijssen at vortech.nl> wrote:
> >> A solution seems to be that the style sheet is present on a public server, so that it can be retrieved using http. This should be fine for all browsers.
> >   This does not work for Firefox (generates an error code) Safari (rejected as unsafe since does not come from the same domain as the input file) or Chrome (also rejected as unsafe).
> >   Putting the style file in the same directory as the xml file works for Firefox but is rejected as unsafe by Chrome and Safari (does not look possible to pass obscure command line arguments to Chrome on the Mac).
> >    So it appears next to hopeless (apparently the browsers really want you to be retrieving everything via a web sever to view them).
> >    I found that that one can embed directly into a file some style information with the <style> </style>. I tried this with your style file and it didn't work (I suspect because your style file uses all kinds of cool stuff not supported by <style> </style>.)  If you can figure out how to include all the style information directly into the generated file that would be the ideal solution.
> >   Barry
> >> Maybe somewhere on https://emea01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.mcs.anl.gov%2Fpetsc&data=02%7C01%7Ckoos.huijssen%40vortech.nl%7C66e17fb5b9c543b8bd2108d58b6f727e%7C5fe8f8070fe44cdf8dc636475a0b8555%7C0%7C0%7C636568233169349605&sdata=X%2FjZOjvsOlWR2NDbYjnQnBxocE2fe2zjSwcpgu%2F6Tp0%3D&reserved=0 ...?
> >> Regards,
> >> Koos
> >> On 03/16/2018 12:04 PM, Klaij, Christiaan wrote:
> >>> Thanks Koos! We have the same problem on microsoft internet explorer. Safari does some magic for sure.
> >>> Chris
> >>> dr. ir.Christiaan Klaij | Senior Researcher | Research & Development
> >>> MARIN | T +31 317 49 33 44 | C.Klaij at marin.nl |
> >>> https://emea01.safelinks.protection.outlook.com/?url=www.marin.nl&dat
> >>> sdata=5%2Bf0QNYiAYF4vYD8nwWXGS7aLPU1GkXoQvUPXutoB%2B4%3D&reserved=0
> >>> <imagecbaa01.PNG> <imagea81454.PNG> <imagebf5793.PNG>
> >>> <imageafd0a5.PNG> MARIN news: Putting a new spin on propeller design
> >>> From: Koos Huijssen <koos.huijssen at vortech.nl>
> >>> Sent: Friday, March 16, 2018 12:02 PM
> >>> To: Klaij, Christiaan; Smith, Barry F.
> >>> Cc: petsc-dev at mcs.anl.gov
> >>> output
> >>> Hi Chris,
> >>> Indeed, this is exactly the issue. When we investigated this it seemed to work on Barry's system, but it has never worked on mine either. The browsers do not allow hard paths to be used for the xml style sheet.
> >>> For Chrome there is an extra thing. If you launch Chrome with the flag '--allow-file-access-from-files' it should give the desired result (see here).
> >>> A note in the manual would surely be a good thing.
> >>> With kind regards,
> >>> Koos
> >>> On 03/16/2018 11:54 AM, Klaij, Christiaan wrote:
> >>>> Barry,
> >>>> I've tried it quickly with petsc-3.8.3 and
> >>>> snes/examples/tutorials/ex70.c and it seems to work except for the
> >>>> stylesheet. The xml log has this header in my case:
> >>>> href="/home/cklaij/ReFRESCO/Dev/trunk/Libs/build/petsc-3.8.3-dbg/sha
> >>>> re/petsc/xml/performance_xml2html.xsl"?>
> >>>> Even though the path is correct, both Firefox and Chrome on linux do
> >>>> not load the stylesheet. I have to
> >>>> 1) copy "performance_xml2html.xsl" to the directory which contains
> >>>> the xml log (a symlink won't do),
> >>>> 2) then edit the header to href="performance_xml2html.xsl".
> >>>> These steps work for Firefox, but not for Chrome (it just shows a
> >>>> blank page).
> >>>> If I remember correctly (Koos?) then this problem was due to some
> >>>> browser safety stuff which can't be avoided. If this is still true
> >>>> and not fixable, we should probably add a note in the manual
> >>>> explaining both steps?
> >>>> Chris
> >>>> dr. ir. Christiaan Klaij  | Senior Researcher | Research &
> >>>> Development MARIN | T +31 317 49 33 44 | mailto:C.Klaij at marin.nl |
> >>>> w.marin.nl&data=02%7C01%7Ckoos.huijssen%40vortech.nl%7Cf467bc9cbee84
> >>>> 636730208d58b2c45c1%7C5fe8f8070fe44cdf8dc636475a0b8555%7C0%7C0%7C636
> >>>> 567944636671153&sdata=wf%2BYdEvdpvMh9aK7D51yBDHFQvlziBS9U3ArOA85etE%
> >>>> 3D&reserved=0
> >>>> MARIN news:
> >>>> w.marin.nl%2Fweb%2FNews%2FNews-items%2FFrequency-of-spill-model-for-
> >>>> area-risk-assessment-of-shipsource-oil-spills-in-Canadian-waters-1.h
> >>>> tm&data=02%7C01%7Ckoos.huijssen%40vortech.nl%7Cf467bc9cbee8463673020
> >>>> 8d58b2c45c1%7C5fe8f8070fe44cdf8dc636475a0b8555%7C0%7C0%7C63656794463
> >>>> 6671153&sdata=2TVwn1x5EZuNHzVHCMO1BLNNRMv%2BrSe4eOJ3tQ7vhJg%3D&reser
> >>>> ved=0
> >>>> ________________________________________
> >>>> Sent: Thursday, March 15, 2018 3:00 PM
> >>>> Cc: Koos Huijssen;
> >>>> ; Bas van 't Hof
> >>>> output
> >>>>   It is in 3.8 please let us know if you have any trouble with it.
> >>>>   Barry
> >>>>> On Mar 15, 2018, at 3:03 AM, Klaij, Christiaan <C.Klaij at marin.nl>
> >>>>> wrote:
> >>>>> Hi Barry,
> >>>>> It's been a while and I'll soon be upgrading our production
> >>>>> software from petsc-3.7.5 to petsc-3.8.3. Can you tell me if the
> >>>>> nested event logging made it into 3.8? If so, I would probably
> >>>>> remove our own version in favor of the petsc maintained version.
> >>>>> Best regards,
> >>>>> Chris
> >>>>> Development MARIN | T +31 317 49 33 44 | C.Klaij at marin.nl |
> >>>>> ata=02%7C01%7Ckoos.huijssen%40vortech.nl%7Cf467bc9cbee84636730208d5
> >>>>> 8b2c45c1%7C5fe8f8070fe44cdf8dc636475a0b8555%7C0%7C0%7C6365679446366
> >>>>> 71153&sdata=GPHrId893OZ0dHpzLHEHgjmQHBOsest1JEl6sZ6wef4%3D&reserved
> >>>>> =0
> >>>>> <image15100b.PNG> <imageb2c83e.PNG> <imagebd077a.PNG>
> >>>>> <image2e1442.PNG> MARIN news: Numerical study of cavitation on a
> >>>>> NACA0015 hydrofoil: solution verification
> >>>>> From: Koos Huijssen
> >>>>> Sent: Friday, August 12, 2016 8:07 AM
> >>>>> To: Barry Smith
> >>>>> Cc:
> >>>>> ; Klaij, Christiaan; Bas van 't Hof
> >>>>> output
> >>>>> Hi Barry,
> >>>>> Looking forward to that!
> >>>>> Koos
> >>>>> From: Barry Smith
> >>>>> Sent: Friday, August 12, 2016 4:02:42 AM
> >>>>> To: Koos Huijssen
> >>>>> Cc:
> >>>>> output
> >>>>>  Thanks. This will be in master soon.
> >>>>>   Barry
> >>>>>> On Aug 8, 2016, at 5:15 AM, Koos Huijssen
> >>>>>> wrote:
> >>>>>> Hi Barry,
> >>>>>> The fix is to replace the "j<=depth" on line 736 with "j<depth".
> >>>>>> So it should read
> >>>>>> for (j=0; same && j<depth; j++) { same = (same &&  nstMyPath[j] ==
> >>>>>> nstPath[j]) ? PETSC_TRUE : PETSC_FALSE;}
> >>>>>> That should resolve the valgrind issue.
> >>>>>> With kind regards,
> >>>>>> Koos
> >>>>>> From: Barry Smith [
> >>>>>> Sent: vrijdag 5 augustus 2016 22:39
> >>>>>> To: Koos Huijssen
> >>>>>> Cc:
> >>>>>> petsc-dev at mcs.anl.gov; Klaij, Christiaan <C.Klaij at marin.nl>; Bas
> >>>>>> van 't Hof <bas.vanthof at vortech.nl>
> >>>>>> output
> >>>>>>   There appears to be an error indicated by valgrind at:
> >>>>>> ftp://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/08/04/exa
> >>>>>> mples_master_arch-linux-pkgs-valgrind_grind.log
> >>>>>> Note that the nstPath[] arrays only seem to filled up to but not including depth but the  "same" loop has j<=depth. Could you please clarify how I should fix this?
> >>>>>>     if (i<nTimers) {
> >>>>>>       for (j=0;             j<tree[i].depth; j++) nstMyPath[j] = tree[i].nstPath[j];
> >>>>>>       for (j=tree[i].depth; j<depth;         j++) nstMyPath[j] = illegalEvent;
> >>>>>>     } else {
> >>>>>>       for (j=0;             j<depth;         j++) nstMyPath[j] = illegalEvent;
> >>>>>>     /* Communicate with other processes to obtain the next path and its depth */
> >>>>>>     ierr = MPIU_Allreduce(nstMyPath, nstPath, depth, MPI_INT, MPI_MIN, comm);CHKERRQ(ierr);
> >>>>>>     for (j=depth-1; (int) j>=0; j--) {
> >>>>>>       if (nstPath[j]==illegalEvent) depth=j;
> >>>>>>     if (depth>0) {
> >>>>>>       /* If the path exists */
> >>>>>>       /* check whether the next path is the same as this process's next path */
> >>>>>>       same = PETSC_TRUE;
> >>>>>>       for (j=0; same && j<=depth; j++) { same = (same &&
> >>>>>> nstMyPath[j] == nstPath[j]) ? PETSC_TRUE : PETSC_FALSE;}
> >>>>>>> On Aug 4, 2016, at 5:01 PM, Koos Huijssen
> >>>>>>> wrote:
> >>>>>>> Hi Barry,
> >>>>>>> I did some analysis on the results, but I see nothing strange. The missing MatAssemblyBegin could be because its time falls under the threshold of 0.01% of the total runtime, in which case it is left out of the tree. I ran the same case, and I got both Begin/End operations, but both at 0% (so probably both dwindling around the 0.01% threshold). The MatAssemblyBegin/MatAssemblyEnd pair are part of the SNESSolve routine, but they are not located within the SNES_Solve log event. This event only registers the time spent in the solve routine in snes->ops->solve. If I set an event around the call to SNESSolve in ex19.c, they do appear within that event. Maybe something to do with MatInterpolate or DMInterpolate?
> >>>>>>> Since the log events have never been used in a nested logging before, it could be that this type of misunderstanding will occur more often whenever a log event is not one-to-one coupled to its routine but to a section within that routine.
> >>>>>>> With kind regards,
> >>>>>>> Koos
> >>>>>>> From: Koos Huijssen
> >>>>>>> Sent: donderdag 4 augustus 2016 22:12
> >>>>>>> To: Koos Huijssen
> >>>>>>> Subject: Fwd: [petsc-dev] Nested event logging and human friendly
> >>>>>>> output
> >>>>>>> Begin doorgestuurd bericht:
> >>>>>>> Van: Barry Smith
> >>>>>>> Datum: 17 juli 2016 04:44:04 CEST
> >>>>>>> Aan: Koos Huijssen
> >>>>>>> Kopie: Richard Mills
> >>>>>>> <richardtmills at gmail.com>
> >>>>>>> "petsc-dev at mcs.anl.gov" <petsc-dev at mcs.anl.gov> , "Klaij,
> >>>>>>> Christiaan"
> >>>>>>> <C.Klaij at marin.nl>, "Bas van 't Hof" <bas.vanthof at vortech.nl>
> >>>>>>> Onderwerp: Antw.: [petsc-dev] Nested event logging and human
> >>>>>>> friendly output
> >>>>>>> Thank you very much for fixing the errors I introduced and improving the code. I have put it into branch barry/fix-xml-logging and merged to next for testing.
> >>>>>>> I do have one concern, when I run on
> >>>>>>> src/snes/examples/tutorials/ex19.c with no options (see attached
> >>>>>>> result) <joe.xml> it lists a MatAssemblyEnd() as a top-level event (but not a MatAssemblyBegin()) but there is no MatAssemblyEnd() at the top level, they should all be occurring inside the SNESSolve() and when I run in the debugger all the MatAssemblyEnd() occur within the SNESSolve(). I am not sure why it incorrectly locates the MatAssemblyEnd() as a top level event?
> >>>>>>> Thanks again
> >>>>>>> Barry
> >>>>>>> On Jul 8, 2016, at 7:59 AM, Koos Huijssen
> >>>>>>> wrote:
> >>>>>>> Dear Barry,
> >>>>>>> I found some time to fix the issues with the nested timers. The
> >>>>>>> attached patch file should work on commit
> >>>>>>> c03b0cd 2016-07-07 | Merge branch 'stefano_zampini/hypre-ams-zerointerior-feature'
> >>>>>>> What I have found is the following:
> >>>>>>> - There were some issues with the merging of the code into the Petsc code base. I have reviewed the merge and fixed this (mainly the section around depth/maxdepth determination).
> >>>>>>> - There was indeed a fundamental issue, concerning a wrong assumption that the PetscLogEvent id =0 was reserved for the overall 'awake' root event. As it was also used for a normal event, this normal event was mistakenly considered as the root event which caused some trouble. I fixed the code. The issue of the single-event example giving a crash is now resolved as well.
> >>>>>>> - When running snes/examples/tutorial/ex56, I found that a timer in DMPlexDistribute was not properly ended. If fixed this.
> >>>>>>> With regard to the latter I wonder why the 'standard' timer events did not notice the fact that the DMPLEX_Distribute was not closed and that it should count as the event with the longest evaluation time. Could it be that the logging disregards any timers that are still open? I was thinking of including a warning message in the nested timers for any open timers at the time of the log generation, but I haven't done that for now.
> >>>>>>> One thing that is still open is the fact that the nested timers are only considering the timings of the events as far as they are logged in the Main Stage. Timings in other stages are simply ignored. For instance, with the example snes/examples/tutorial/ex56.c, we will only get meaningful nested timing information from the ascii_xml viewer if we set log_stages = PETSC_FALSE on line 13. For now, I see three possible approaches to resolve this:
> >>>>>>> - Tell the users that they should turn off stages in their code if they would like to use the nested timers. Given the fact that the nested timer functionality basically makes the stages obsolete, this could be a future option.
> >>>>>>> - After the Main Stage is pushed in PetscLogInitialize, disable the PetscLogStagePush() and PetscLogStagePop() functionality if the ascii_xml viewer is selected for output.
> >>>>>>> - Adjust the xmllogevent functions to consider the eventPerfInfo array of all stages that are in use. This is however a complex code adjustment which I would not prefer to do, also given the fact that the staging functionality is not relevant for the nested timers.
> >>>>>>> Please let me know what you think of the above. Could you please include the patch in the Petsc code?
> >>>>>>> With kind regards,
> >>>>>>> Koos Huijssen
> >>>>>>> __________________________________________
> >>>>>>> VORtech BV - Scientific software engineers
> >>>>>>> Dr.ir. Koos Huijssen
> >>>>>>> P.O. Box 260
> >>>>>>> 2600 AG Delft
> >>>>>>> The Netherlands
> >>>>>>> phone  +31(0)15-285 0125
> >>>>>>> mobile +31(0)6-3333 0803
> >>>>>>> email
> >>>>>>> web
> >>>>>>> https://emea01.safelinks.protection.outlook.com/?url=www.vortech.
> >>>>>>> nl&data=02%7C01%7Ckoos.huijssen%40vortech.nl%7Cf467bc9cbee8463673
> >>>>>>> 0208d58b2c45c1%7C5fe8f8070fe44cdf8dc636475a0b8555%7C0%7C0%7C63656
> >>>>>>> 7944636671153&sdata=TIwKTlC0%2FBVOWA6TXzQQKkPUcMYhsAmKagm0W9MXPg8
> >>>>>>> %3D&reserved=0
> >>>>>>> -----Oorspronkelijk bericht-----
> >>>>>>> Van: Barry Smith [
> >>>>>>> Verzonden: maandag 6 juni 2016 17:21
> >>>>>>> Aan: Koos Huijssen
> >>>>>>> CC: Richard Mills;
> >>>>>>> ; Klaij, Christiaan
> >>>>>>> Onderwerp: Re: [petsc-dev] Nested event logging and human
> >>>>>>> friendly output
> >>>>>>> Whenever you can get to it is fine.
> >>>>>>> Thanks
> >>>>>>> Barry
> >>>>>>> On Jun 6, 2016, at 8:14 AM, Koos Huijssen
> >>>>>>> wrote:
> >>>>>>> Dear Barry,
> >>>>>>> Thanks for notifying us of these issues. There seems to be quite a few fundamental issues with the nested timer functionality and the xml output. We will have to check the case, reproduce the problems and start looking into the code. However, currently we are unable to do so. We may be able to look into the issue in a month or so. Would that be okay for you? If so, then we will come back on the issue in the beginning of July.
> >>>>>>> With kind regards,
> >>>>>>> Koos
> >>>>>>> From: Barry Smith [
> >>>>>>> Sent: zondag 5 juni 2016 1:19
> >>>>>>> To: Koos Huijssen
> >>>>>>> ; Richard Mills
> >>>>>>> Cc:
> >>>>>>> output
> >>>>>>> We are having some major problems with your xml nested logging on a slightly more complicated example and I've been trying to debug it with no success. So I went back to my original commit bb1d7374b64f295b2ed5ff23b89435d65e905a54 and found something I was not expecting. When I run src/snes/examples/tutorials/ex19 with logging it generates the attached image. Which is wrong, note that SNESJacobianEvaluate, KSPSolve etc are embedded in the SNES solver but this is not properly displayed. Shouldn't they be in one level from the SNESSolve? Is this a bug, a feature? Or ...?
> >>>>>>> Thanks for any information,
> >>>>>>> Barry
> >>>>>>> The major problem we are seeing with the nested logging is in the
> >>>>>>> branch mark/snes-ex56c when we run
> >>>>>>> src/snes/examples/tutorials/ex56 with
> >>>>>>> petscmpiexec -n 1 ./ex56 -dm_refine 2 -ne 8 -alpha 1.e-3
> >>>>>>> -two_solves false  -petscspace_poly_tensor -petscspace_order 1
> >>>>>>> -ksp_type cg -ksp_monitor_short -ksp_rtol 1.e-8 -pc_type gamg
> >>>>>>> -pc_gamg_type agg -pc_gamg_agg_nsmooths 1
> >>>>>>> -pc_gamg_coarse_eq_limit 100 -pc_gamg_reuse_interpolation true
> >>>>>>> -pc_gamg_square_graph 1 -pc_gamg_threshold 0.0
> >>>>>>> -ksp_converged_reason -use_mat_nearnullspace true
> >>>>>>> -mg_levels_ksp_max_it 2 -mg_levels_ksp_type chebyshev
> >>>>>>> -mg_levels_esteig_ksp_type cg -mg_levels_esteig_ksp_max_it 10
> >>>>>>> -mg_levels_ksp_chebyshev_esteig 0,0.05,0,1.05 -mg_levels_pc_type
> >>>>>>> sor -mat_block_size 3 -petscpartitioner_type chaco -log_view
> >>>>>>> ascii:ex56-intel2016_knl_fast_64ranks_ne8_dmrefine3_log.xml:ascii
> >>>>>>> _xml
> >>>>>>> it messes up the nesting and has total nonsense for the numerical values of time, for example in the different events, while the traditional -log_summary prints out reasonable results. It seems somehow either to be not gathering the data properly into the nested event data structures you have or not properly processing the data to generate the xml. I tried debugging but the logic is unclear to me.
> >>>>>>> Simple programs such as:
> >>>>>>> ierr = PetscLogEventRegister("Event1",0,&event1);CHKERRQ(ierr);
> >>>>>>> ierr = PetscLogEventBegin(event1,0,0,0,0);CHKERRQ(ierr);
> >>>>>>> ierr = PetscSleep(1.0);CHKERRQ(ierr); ierr =
> >>>>>>> PetscLogEventEnd(event1,0,0,0,0);CHKERRQ(ierr);
> >>>>>>> produce:
> >>>>>>> [0]PETSC ERROR: Petsc has generated inconsistent data [0]PETSC ERROR:
> >>>>>>> Depth 2 > maxdepth + 1 1 [0]PETSC ERROR: See
> >>>>>>> Fwww.mcs.anl.gov%2Fpetsc%2Fdocumentation%2Ffaq.html&data=02%7C01%
> >>>>>>> 7Ckoos.huijssen%40vortech.nl%7Cf467bc9cbee84636730208d58b2c45c1%7
> >>>>>>> C5fe8f8070fe44cdf8dc636475a0b8555%7C0%7C0%7C636567944636671153&sd
> >>>>>>> ata=7qyvMdTARqZ%2Fj2F3dyI27vL4eaTUFZ9RJPonqdl5fcY%3D&reserved=0
> >>>>>>> for trouble shooting.
> >>>>>>> [0]PETSC ERROR: Petsc Development GIT revision:
> >>>>>>> v3.7.1-405-gbb23584 GIT Date: 2016-06-04 11:37:36 -0500 [0]PETSC
> >>>>>>> ERROR: ./ex30 on a arch-xmllog named Barrys-MacBook-Pro.local by
> >>>>>>> barrysmith Sat Jun  4
> >>>>>>> 18:13:00 2016 [0]PETSC ERROR: Configure options --download-chaco
> >>>>>>> --with-mpi-dir=/Users/barrysmith/libraries PETSC_ARCH=arch-xmllog
> >>>>>>> [0]PETSC ERROR: #1 PetscCreateLogTreeNested() line 719 in
> >>>>>>> /Users/barrysmith/Src/petsc/src/sys/logging/xmllogevent.c
> >>>>>>> ierr = PetscLogEventRegister("Event2",0,&event2);CHKERRQ(ierr);
> >>>>>>> ierr = PetscLogEventRegister("Event3",0,&event3);CHKERRQ(ierr);
> >>>>>>> PetscLogEventBegin(event2,0,0,0,0);CHKERRQ(ierr);
> >>>>>>> PetscLogEventBegin(event3,0,0,0,0);CHKERRQ(ierr);
> >>>>>>> PetscLogEventEnd(event3,0,0,0,0);CHKERRQ(ierr);
> >>>>>>> ierr = PetscLogEventEnd(event2,0,0,0,0);CHKERRQ(ierr);
> >>>>>>> ierr = PetscLogEventEnd(event1,0,0,0,0);CHKERRQ(ierr);
> >>>>>>> doesn't crash but doesn't nest event2 and 3 in one but does nest 3 into 2.
> >>>>>>> If seems that the ordering of the event values mater, if  I
> >>>>>>> change the registration order to
> >>>>>>> then it crashes with
> >>>>>>> 18:17:40 2016 [0]PETSC ERROR: Configure options --download-chaco
> >>>>>>> [0]PETSC ERROR: #2 PetscLogView_Nested() line 1399 in
> >>>>>>> Possibly related issue: If you run an example that has nothing that is actually logged but attempt to use the -log_view it crashes, there is some implicit assumption in your generation of the xml that some values will be non-empty.
> >>>>>>> On Sep 18, 2<image002.png>015, at 10:09 PM, Barry Smith
> >>>>>>> wrote:
> >>>>>>> Thank you for contributing the nested logging. I have
> >>>>>>> incorporated into the PETSc branch barry/xml-nested-logging  if
> >>>>>>> you look at
> >>>>>>> 2Fbitbucket.org%2Fpetsc%2Fpetsc%2Fcommits%2Fbb1d7374b64f295b2ed5f
> >>>>>>> f23b894&data=02%7C01%7Ckoos.huijssen%40vortech.nl%7Cf467bc9cbee84
> >>>>>>> 636567944636671153&sdata=FwS%2FOWxWFpeBNYTYWoROFjewhf304uPHdZKAYx
> >>>>>>> QqGZA%3D&reserved=0
> >>>>>>> 35d65e905a54?at=masteryou can see exactly what I have
> >>>>>>> incorporated into PETSc.  I will merge it into next for
> >>>>>>> portability testing in the next couple of days. I expect over
> >>>>>>> time as I understand it better I will be able to improve its
> >>>>>>> integration with PETSc.  Currently to generate the nested logging
> >>>>>>> it is as simple to use as -log_view :filename.xml:ascii_xml
> >>>>>>> Thanks again,
> >>>>>>> Barry
> >>>>>>> On Sep 14, 2015, at 7:45 AM, Koos Huijssen
> >>>>>>> wrote:
> >>>>>>> Dear PETSc development team,
> >>>>>>> We have developed an extension of the PETSc event logging facilities that has the following advanced features:
> >>>>>>> - It allows logging of events in the form of a nested tree. So if some function is called from multiple locations in the code, these instances are distinguished. This in contrast with the standard event logger, which only logs the amount of total call time.
> >>>>>>> - It allows the output report to be formatted in XML format. This
> >>>>>>> output can then be viewed in a human-friendly form in a web browser with the use of the XSL Transformation script performance_xml2html.xsl. The html features an nested timings tree that can be expanded and collapsed as desired.
> >>>>>>> This tool has been very useful for us to analyze the code and pinpoint performance bottle necks. We think that it can be useful for others as well, and therefore we are providing the code here for integration in the open source distribution of PETSc.
> >>>>>>> For more information I refer to the included manual. We have also provided a test program and a makefile for convenience. The test program can be run using MPI with for instance 3-6 processes.
> >>>>>>> I apologize for not using the git repo to submit the developed code. I also apologize for not adhering to the PETSc coding standards (or at least not as far as I know), but I hope that it is not too far off.. Apart from the whole capital/underscore standardization stuff one issue may require special attention, namely the (ab)use of the format PETSc_VIEWER_ASCII_IMPL for signaling the XML format in XMLViewer.c. I couldn't find an already existing and better fitting format, but it could be necessary to add a new format here for this purpose.
> >>>>>>> Can you take it up from here and realize the integration of the code in the PETSc distribution?
> >>>>>>> With kind regards,
> >>>>>>> Koos Huijssen
> >>>>>>> _________________________________________________________________
> >>>>>>> ___
> >>>>>>> ___
> >>>>>>> P.O. Box 260
> >>>>>>> 2600 AG Delft
> >>>>>>> The Netherlands
> >>>>>>> email
> >>>>>>> web
> >>>>>>> %3D&reserved=0
> >>>>>>> ___
> >>>>>>> <timers.tar.gz>
> >>>>>>> <0001-ascii_xml-logging-fixes-to-nested-tree-generation-an.patch>
> >>> ____________________________________________________________________
> >>> P.O. Box 260
> >>> 2600 AG Delft
> >>> The Netherlands
> >>> phone  +31(0)15-251 1942
> >>> email
> >>> web
> >>> https://emea01.safelinks.protection.outlook.com/?url=www.vortech.nl&d
> >>> 5&sdata=9KGCeKT%2BtniOVjqm6q0IjcP2C43ejikCLTsVu3egQFc%3D&reserved=0
> >> P.O. Box 260
> >> 2600 AG Delft
> >> The Netherlands
> >> email
> >> web
> >> https://emea01.safelinks.protection.outlook.com/?url=www.vortech.nl&da
