[petsc-dev] Tests are not working for me in next
Jed Brown jed at jedbrown.org
Mon Mar 19 14:51:16 CDT 2018
Satish Balay <balay at mcs.anl.gov> writes:
>> >> > >> Thanks for the diagnosis.  Can we use @rpath/libpetsc.3.08.dylib?  Then
>> >> > >> we wouldn't need to run install_name_tool either.  If we want the
>> >> > >> absolute path written into the dylib, I can do that.
>> >> > > You mean '-install_name ${PREFIXDIR}/lib/libpetsc.3.08.dylib'? Yes - this should eliminate the need for install_name_tool in 'make install' [and that code can be removed]
>> >> > No, I mean -install_name @rpath/libpetsc.3.08.dylib.
>> >> mpicc -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-no_compact_unwind    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -Qunused-arguments -fvisibility=hidden -g3  -dynamiclib -install_name -install_name @rpath/libpetsc.3.08.dylib -compatibility_version 3.08 -current_version 3.08.3 -single_module -multiply_defined suppress -undefined dynamic_lookup -o arch-prefix/lib/libpetsc.3.08.3.dylib ...
>> >> <snip>
>> >> clang: error: no such file or directory: '@rpath/libpetsc.3.08.dylib'
>> >> make[2]: *** [arch-prefix/lib/libpetsc.3.08.3.dylib] Error 1
>> > Ops - I have -install_name option listed twice.
>> > removing the dupliate..
>> > balay at ipro^~/petsc(next) $ make PETSC_DIR=/Users/balay/pinstall PETSC_ARCH="" test
>> > Running test examples to verify correct installation
>> > Using PETSC_DIR=/Users/balay/pinstall and PETSC_ARCH=
>> > C/C++ example src/snes/examples/tutorials/ex19 run successfully with 1 MPI process
>> > C/C++ example src/snes/examples/tutorials/ex19 run successfully with 2 MPI processes
>> > Fortran example src/snes/examples/tutorials/ex5f run successfully with 1 MPI process
>> > Completed test examples
>> > Now to evaluate the computer systems you plan use - do:
>> > make PETSC_DIR=/Users/balay/pinstall PETSC_ARCH= streams
>> > balay at ipro^~/petsc(next) $ otool -L ~/pinstall/lib/libpetsc.dylib
>> > /Users/balay/pinstall/lib/libpetsc.dylib:
>> > 	@rpath/libpetsc.3.08.dylib (compatibility version 3.8.0, current version 3.8.3)
>> > 	/System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib (compatibility version 1.0.0, current version 1.0.0)
>> > 	/System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib (compatibility version 1.0.0, current version 1.0.0)
>> > 	/usr/lib/libc++.1.dylib (compatibility version 1.0.0, current version 400.9.0)
>> > 	/usr/lib/libSystem.B.dylib (compatibility version 1.0.0, current version 1252.0.0)
>> > 	/Users/balay/soft/mpich-3.2/lib/libmpifort.12.dylib (compatibility version 14.0.0, current version 14.0.0)
>> > 	/Users/balay/soft/mpich-3.2/lib/libmpi.12.dylib (compatibility version 14.0.0, current version 14.0.0)
>> > 	/Users/balay/soft/mpich-3.2/lib/libpmpi.12.dylib (compatibility version 14.0.0, current version 14.0.0)
>> > 	/usr/local/opt/gcc/lib/gcc/7/libgfortran.4.dylib (compatibility version 5.0.0, current version 5.0.0)
>> > 	/usr/local/lib/gcc/7/libgcc_s.1.dylib (compatibility version 1.0.0, current version 1.0.0)
>> > 	/usr/local/opt/gcc/lib/gcc/7/libquadmath.0.dylib (compatibility version 1.0.0, current version 1.0.0)
>> > 	/Users/balay/soft/mpich-3.2/lib/libmpicxx.12.dylib (compatibility version 14.0.0, current version 14.0.0)
>> > Ok - this works..
>> The consequence here is that users would be expected to use -Wl,-rpath,
>> when linking to libpetsc.dylib, where now they probably get away without
>> (on OSX).
> Using '-install_name ${PREFIXDIR}/lib/libpetsc.3.08.dylib' would keep the current behavior.
Right, but that would prevent it from working in the build directory.
If you want both, you either need to relink or run install_name_tool as
we currently do.  With @rpath, you don't need any of that.  There are
arguments in favor of either convention.
