[petsc-dev] Tests are not working for me in next
Mon Mar 19 14:31:25 CDT 2018
On Mon, 19 Mar 2018, Jed Brown wrote:
> Satish Balay <balay at mcs.anl.gov> writes:
> >> Thanks for the diagnosis.  Can we use @rpath/libpetsc.3.08.dylib?  Then
> >> we wouldn't need to run install_name_tool either.  If we want the
> >> absolute path written into the dylib, I can do that.
> > You mean '-install_name ${PREFIXDIR}/lib/libpetsc.3.08.dylib'? Yes - this should eliminate the need for install_name_tool in 'make install' [and that code can be removed]
> No, I mean -install_name @rpath/libpetsc.3.08.dylib.
mpicc -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-no_compact_unwind    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -Qunused-arguments -fvisibility=hidden -g3  -dynamiclib -install_name -install_name @rpath/libpetsc.3.08.dylib -compatibility_version 3.08 -current_version 3.08.3 -single_module -multiply_defined suppress -undefined dynamic_lookup -o arch-prefix/lib/libpetsc.3.08.3.dylib ...
<snip>
clang: error: no such file or directory: '@rpath/libpetsc.3.08.dylib'
make[2]: *** [arch-prefix/lib/libpetsc.3.08.3.dylib] Error 1
Satish
