[petsc-dev] Tests are not working for me in next
Jed Brown
jed at jedbrown.org
Mon Mar 19 12:44:33 CDT 2018
Satish Balay <balay at mcs.anl.gov> writes:
> Ok - the issue is coming from the change in jed/gmakefile-paths
> commit 8e69c5ec7dbec5c4ff0e2255fa41e86223635a8c
> Author: Jed Brown <jed at jedbrown.org>
> Previously we had:
> /Users/petsc/petsc.next/arch-osx-10.6/bin/mpicc -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-no_compact_unwind -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-no_compact_unwind -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -Qunused-arguments -fvisibility=hidden -g3 -dynamiclib -install_name arch-osx-10.6/lib/libpetsc.3.08.dylib -compatibility_version 3.08 -current_version 3.08.3 -single_module -multiply_defined suppress -undefined dynamic_lookup -o arch-osx-10.6/lib/libpetsc.3.08.3.dylib ...
I assume the above and below are backwards?
> Now we have:
> /Users/petsc/petsc.master/arch-osx-10.6/bin/mpicc -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-no_compact_unwind -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-no_compact_unwind -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -Qunused-arguments -fvisibility=hidden -g3 -dynamiclib -install_name /Users/petsc/petsc.master/arch-osx-10.6/lib/libpetsc.3.08.dylib -compatibility_version 3.08 -current_version 3.08.3 -single_module -multiply_defined suppress -undefined dynamic_lookup -o /Users/petsc/petsc.master/arch-osx-10.6/lib/libpetsc.3.08.3.dylib .....
> '-install_name arch-osx-10.6/lib/libpetsc.3.08.dylib' vs
> '-install_name /Users/petsc/petsc.master/arch-osx-10.6/lib/libpetsc.3.08.dylib'
> is causing this difference.
Thanks for the diagnosis. Can we use @rpath/libpetsc.3.08.dylib? Then
we wouldn't need to run install_name_tool either. If we want the
absolute path written into the dylib, I can do that.
