[petsc-dev] Is ./configure --help broken?
Matthew Knepley
knepley at gmail.com
Fri Mar 16 12:21:44 CDT 2018
On Fri, Mar 16, 2018 at 1:17 PM, Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> > I agree. We should remove all code (about 2/3 of it) which does a
> > hierarchy of communicating dicts (the original design). That would
> > make everything simple. No threads, no parents, etc. We leave in the
> > help the way we want it, types for args, etc. One thing its notably
> > missing, and that PETSc Options are missing, is listing the thing that
> > set the option (default, command line, code, env).
> Does RDict even need to be persistent? Who all reads it? I wonder if
> an existing human-readable file would be sufficient instead?
I think we should persist the entire set of options used to configure for
later
interrogation, however we have not done that much so far.
We do need to persist the configure objects.
Matt
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180316/dd4c84d3/attachment.html>
