[petsc-dev] Test Code Coverage (gcov) page is missing
    Smith, Barry F.
    bsmith at mcs.anl.gov
    Fri Mar 16 11:24:12 CDT 2018
  Any suggestions on how to achieve this?
> On Mar 16, 2018, at 11:15 AM, Junchao Zhang <jczhang at mcs.anl.gov> wrote:
> For each tested line, it would be helpful if we also show the test (one is enough) that tested the line.
> --Junchao Zhang
> On Fri, Mar 16, 2018 at 10:40 AM, Balay, Satish <balay at mcs.anl.gov> wrote:
> On Fri, 16 Mar 2018, Junchao Zhang wrote:
> > The coverage page at http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/index.html
> > is missing. When I read certain PETSc code, I feel some if conditions will
> > never be met (i.e., there are dead statements). To confirm that, I want to
> > know which tests run into that condition.
> Thanks - its updated now.
> Jed,
> I must have messedup the testing of the latest gcov changes..
> [thwomp:petsc/nightlylogs/gcov] petsc> cat ~/nightlylogs/archive/2018/03/16/gcov-snapshot-update.log
> Traceback (most recent call last):
>   File "/sandbox/petsc/petsc.clone/lib/petsc/bin/maint/gcov.py", line 18, in <module>
>     PETSC_ARCH = os.environ['PETSC_ARCH']
>   File "/usr/lib/python2.7/UserDict.py", line 23, in __getitem__
>     raise KeyError(key)
> KeyError: 'PETSC_ARCH'
> So the issue is - this script is run in 2 different modes:
> lib/petsc/bin/maint/gcov.py:        print "         ./gcov.py -run_gcov      "
> lib/petsc/bin/maint/gcov.py:        print "         ./gcov.py -merge_gcov [LOC] tarballs"
> For the second mode is with [LOC] - i.e there is no prior build - i.e no PETSC_ARCH
> So how about the following change?
> diff --git a/lib/petsc/bin/maint/gcov.py b/lib/petsc/bin/maint/gcov.py
> index 6d0e1e0..0a49978 100755
> --- a/lib/petsc/bin/maint/gcov.py
> +++ b/lib/petsc/bin/maint/gcov.py
> @@ -14,10 +14,6 @@ import operator
>  import sys
>  from   time import gmtime,strftime
> -PETSC_DIR = os.environ['PETSC_DIR']
> -PETSC_ARCH = os.environ['PETSC_ARCH']
> -OBJDIR = os.path.join(PETSC_DIR, PETSC_ARCH, 'obj')
>  def run_gcov(gcov_dir):
>      # 1. Runs gcov
> @@ -389,11 +385,15 @@ def make_htmlpage(gcov_dir,LOC,tarballs):
>  def main():
> +    global PETSC_DIR,PETSC_ARCH,OBJDIR
>      USER = os.environ['USER']
>      gcov_dir = "/tmp/gcov-"+USER
> +    PETSC_DIR = os.environ['PETSC_DIR']
>      if (sys.argv[1] == "-run_gcov"):
>          print "Running gcov and creating tarball"
> +        PETSC_ARCH = os.environ['PETSC_ARCH']
> +        OBJDIR = os.path.join(PETSC_DIR, PETSC_ARCH, 'obj')
>          run_gcov(gcov_dir)
>          make_tarball(gcov_dir)
>      elif (sys.argv[1] == "-merge_gcov"):
> Satish
