[petsc-dev] Test parsers is parsing *.c~ files
Thu Mar 15 13:44:46 CDT 2018
On Fri, Mar 16, 2018 at 3:22 AM, Scott Kruger <kruger at txcorp.com> wrote:
> Yes, as you surmise Barry, I am a vim user.
> Based on earlier comments, I have this in config/gmakegentest.py:
>         # Ignore emacs and other temporary files
>         if exfile.startswith("."): continue
>         if exfile.startswith("#"): continue
> I assume that this:
>         if exfile.endwith("~"): continue
> will work.   Do folks see any problems?
Great, that works for me.
   Matt
> Scott
> On 3/14/18 10:05 PM, Smith, Barry F. wrote:
>>    This drives me nuts also, obviously Scott does not use Emacs or he
>> would have make sure long ago that the test harness would not trip over the
>> crumbs of Emacs.
>>     Matt, You'll need to share the exact forms to of the crumbs that are
>> confusing the test harness.
>>     Barry
>> On Mar 14, 2018, at 11:03 PM, Matthew Knepley <knepley at gmail.com> wrote:
>>> This took me forever to find. The parser is parsing emacs backups and
>>> overwriting some tests.
>>>     Matt
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
> Tech-X Corporation               kruger at txcorp.com
> 5621 Arapahoe Ave, Suite A       Phone: (720) 974-1841
> Boulder, CO 80303                Fax:   (303) 448-7756
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180316/847c9761/attachment.html>
