[petsc-dev] [mpich-discuss] Is mpich/master:a8a2b30fd21 tested with Petsc?
Eric Chamberland
Eric.Chamberland at giref.ulaval.ca
Wed Mar 14 02:35:23 CDT 2018
fwiw, the actual mpich/master branch doesn't passes the PETSc "make
test" after a fresh installation... It hangs just afer the 1 MPI
process test, meaning it is locked into the 2 process test:
make
PETSC_DIR=/pmi/cmpbib/compilation_BIB_dernier_mpich/COMPILE_AUTO/mpich-3.x-debug/petsc-3.8.3-debug
PETSC_ARCH=arch-linux2-c-debug test
Running test examples to verify correct installation
Using
and PETSC_ARCH=arch-linux2-c-debug
C/C++ example src/snes/examples/tutorials/ex19 run successfully with 1
MPI process
^Cmakefile:151: recipe for target 'test' failed
make: [test] Interrupt (ignored)
thanks,
Eric
On 13/03/18 08:07 AM, Eric Chamberland wrote:
> Hi,
> each night we are testing mpich/master with our petsc-based code. I
> don't know if PETSc team is doing the same thing with mpich/master?
> (Maybe it is a good idea?)
> Everything was fine (except the issue
> https://github.com/pmodels/mpich/issues/2892) up to commit 7b8d64debd,
> but since commit mpich:a8a2b30fd21), I have a segfault on a any
> parallel nightly test.
> For example, a 2 process test ends at almost different execution points:
> rank 0:
> #003: /lib64/libpthread.so.0(+0xf870) [0x7f25bf908870]
> #004: /pmi/cmpbib/compilation_BIB_dernier_mpich/COMPILE_AUTO/BIB/bin/BIBMEFGD.opt() [0x64a788]
> #005: /lib64/libc.so.6(+0x35140) [0x7f25bca18140]
> #006: /lib64/libc.so.6(__poll+0x2d) [0x7f25bcabfbfd]
> #007: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x1e4cc9) [0x7f25bd90ccc9]
> #008: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x1ea55c) [0x7f25bd91255c]
> #009: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0xba657) [0x7f25bd7e2657]
> #010: /opt/mpich-3.x_debug/lib/libmpi.so.0(PMPI_Waitall+0xe3) [0x7f25bd7e3343]
> #011: /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(PetscGatherMessageLengths+0x654) [0x7f25c4bb3193]
> #012: /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(VecScatterCreate_PtoS+0x859) [0x7f25c4e82d7f]
> #013: /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(VecScatterCreate+0x5684) [0x7f25c4e4d055]
> #014: /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(VecCreateGhostWithArray+0x688) [0x7f25c4e01a39]
> #015: /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(VecCreateGhost+0x179) [0x7f25c4e020f6]
> rank 1:
> #002: /pmi/cmpbib/compilation_BIB_dernier_mpich/COMPILE_AUTO/GIREF/lib/libgiref_opt_Util.so(traitementSignal+0x2bd0) [0x7f62df8e7310]
> #003: /lib64/libc.so.6(+0x35140) [0x7f62d3bc9140]
> #004: /lib64/libc.so.6(__poll+0x2d) [0x7f62d3c70bfd]
> #005: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x1e4cc9) [0x7f62d4abdcc9]
> #006: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x1ea55c) [0x7f62d4ac355c]
> #007: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x12c9c5) [0x7f62d4a059c5]
> #008: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x12e102) [0x7f62d4a07102]
> #009: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0xf17a1) [0x7f62d49ca7a1]
> #010: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x3facf) [0x7f62d4918acf]
> #011: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x3fc3d) [0x7f62d4918c3d]
> #012: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0xf18d8) [0x7f62d49ca8d8]
> #013: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x3fb88) [0x7f62d4918b88]
> #014: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x3fc3d) [0x7f62d4918c3d]
> #015: /opt/mpich-3.x_debug/lib/libmpi.so.0(MPI_Barrier+0x27b) [0x7f62d4918edb]
> #016: /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(PetscCommGetNewTag+0x3ff) [0x7f62dbceb055]
> #017: /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(PetscObjectGetNewTag+0x15d) [0x7f62dbceaadb]
> #018: /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(VecScatterCreateCommon_PtoS+0x1ee) [0x7f62dc03625c]
> #019: /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(VecScatterCreate_PtoS+0x29c4) [0x7f62dc035eea]
> #020: /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(VecScatterCreate+0x5684) [0x7f62dbffe055]
> #021: /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(VecCreateGhostWithArray+0x688) [0x7f62dbfb2a39]
> #022: /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(VecCreateGhost+0x179) [0x7f62dbfb30f6]
> Have some other users (PETSc users?) reported problem?
> Thanks,
> Eric
> ps: usual informations:
> mpich logs:
> http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_config.log
> http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_config.system
> http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_mpich_version.txt
> http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_c.txt
> http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_m.txt
> http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_mi.txt
> http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_openmpa_config.log
> http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_mpl_config.log
> http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_pm_hydra_config.log
> http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_pm_hydra_tools_topo_config.log
> http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_mpiexec_info.txt
> Petsc logs:
> http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_configure.log
> http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_make.log
> http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_default.log
> http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_RDict.log
> http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_CMakeLists.txt
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180314/37e21583/attachment.html>
