[petsc-dev] [petsc-maint] Installing with CUDA on a cluster
Satish Balay
balay at mcs.anl.gov
Mon Mar 12 10:24:00 CDT 2018
Thanks Karl.
diff --git a/config/BuildSystem/config/packages/cuda.py b/config/BuildSystem/config/packages/cuda.py
index f5d1395e54..b80ef88c35 100644
--- a/config/BuildSystem/config/packages/cuda.py
+++ b/config/BuildSystem/config/packages/cuda.py
@@ -13,7 +13,7 @@ class Configure(config.package.Package):
self.complex = 1
self.cudaArch = ''
self.CUDAVersion = ''
- self.CUDAMinVersion = '5000' # Minimal cuda version is 5.0
+ self.CUDAMinVersion = '7050' # Minimal cuda version is 7.5
self.hastests = 0
self.hastestsdatafiles= 0
return
@@ -160,7 +160,6 @@ class Configure(config.package.Package):
def configureLibrary(self):
config.package.Package.configureLibrary(self)
- if self.defaultScalarType.lower() == 'complex': self.CUDAMinVersion = '7050'
self.checkCUDAVersion()
self.checkNVCCDoubleAlign()
self.configureTypes()
diff --git a/config/BuildSystem/config/packages/cusp.py b/config/BuildSystem/config/packages/cusp.py
index e6bf4cc118..9ed82f7e78 100644
--- a/config/BuildSystem/config/packages/cusp.py
+++ b/config/BuildSystem/config/packages/cusp.py
self.cxx = 0
self.complex = 0 # Currently CUSP with complex numbers is not supported
self.CUSPVersion = ''
- self.CUSPMinVersion = '400' # Minimal cusp version is 0.4
+ self.CUSPMinVersion = '500' # Minimal cusp version is 0.5.0
return
def setupDependencies(self, framework):
One issue is - I do not know if we have any users using [or requring]
older version. [due to code issues or cuda+os compatibility issues]
And same with cuda.
So I guess we could keep the current defaults - and update them when
any relavent issues come up..
And will plan on using M2090 testbed [with either cuda-7.5 or cuda-8
-arch=sm_20] for forseeable future.
Satish
On Mon, 12 Mar 2018, Karl Rupp wrote:
> Hi Satish,
> thanks for the pull request. I approve the changes, improved appending the
> -Wno-deprecated-gpu-targets to also work on my machine, and have merged
> everything to next.
> > * My fixes should alleviate some of the CUSP installation issues. I
> > don't know enough about CUSP interface wrt the useful features vs
> > other burderns - and if its good to drop it or not. [If needed - we
> > can add in more version dependencies in configure]
> This should be fine for now. In the long term CUSP may be completely
> superseded by NVIDIA's AMGX. Let's see how things develop...
> > * Wrt CUDA - currently my test is with CUDA-7.5. I can try migrating a
> > couple of tests to CUDA-9.1 [on frog]. But what about older
> > releases? Any reason we should drop them? I.e any reason to up the
> > following values?
> See the answer here for a list of CUDA capabilities and defaults:
> https://stackoverflow.com/questions/28932864/cuda-compute-capability-requirements
> We definitely don't need to support compute architecture 1.x (~10 years old),
> as there is no double precision support and hence fairly useless for our
> purposes. Thus, we should be absolutely fine with requiring CUDA 7.0 or
> higher.
> > We do change it for complex build [we don't have a test for this case]
> > '7050'
> I don't remember the exact reason, but I remember that there is one for
> requiring CUDA 7.5 here. Let's use CUDA 7.5 as the minimum for both real and
> complex then?
> > * Our test GUP is M2090 - with Compute capability (version) 2.0.
> > CUDA-7.5 works on it. CUDA-8 gives deprecated warnings. CUDA-9 does
> > not work? So what do we do for such old hardware? Do we keep
> > CUDA-7.5 is the minimum supported version for extended time? [At
> > some point we could switch to minimum version CUDA-8 - if we can get
> > rid of the warnings]
> Your PR silences the deprecation warnings.
> Compute capability 2.0 is fine for our tests for some time to come. We should
> certainly upgrade at some point, yet my experience with GPUs is that older
> GPUs are actually the better test environment, as they tend to reveal bugs
> quicker than newer hardware.
> Best regards,
> Karli
> > * BTW: Wrt --with-cuda-arch, I'm hoping we can get rid of it in favor
> > of CUDAFLAGS [with defaults similar to CFLAGS defaults] - but its
> > not clear if I can easily untangle the dependencies we have [wrt CPP
> > - and others]
> > Or can we get rid of this default alltogether [currently
> > -arch=sm_20] - and expect nvcc to have sane defaults? Then we can
> > probably eliminate all this complicated code. [If cuda-7.5 and higer
> > do this properly - we could use that as the minimum supported version?]
> > Satish
> > On Sat, 10 Mar 2018, Karl Rupp wrote:
> >> Hi all,
> >> a couple of notes here, particularly for Manuel:
> >> * CUSP is repeatedly causing such installation problems, hence we will
> >> soon
> >> drop it as a vector backend and instead only provide a native
> >> CUBLAS/CUSPARSE-based backend.
> >> * you can use this native CUDA backend already now. Just configure with
> >> only
> >> --with-cuda=1 --with-cuda-arch=sm_60 (sm_30 should also work and is
> >> compatible
> >> with Tesla K20 GPUs you may find on other clusters).
> >> * The multigrid preconditioner from CUSP is selected via
> >> -pc_type sa_cusp
> >> Make sure you also use -vec_type cusp -mat_type aijcusp
> >> If you don't need the multigrid preconditioner from CUSP, please
> >> just reconfigure and use the native CUDA-backend with -vec_type cuda
> >> -mat_type
> >> aijcusparse
> >> * Right now only one of {native CUDA, CUSP, ViennaCL} can be activated at
> >> configure time. This will be fixed later this month.
> >> If you're looking for a GPU-accelerated multigrid preconditioner: I just
> >> heard
> >> yesterday that NVIDIA's AMGX is now open source. I'll provide a wrapper
> >> within
> >> PETSc soon.
> >> As Matt already said: Don't expect much more than a modest speedup over
> >> your
> >> existing CPU-based code - provided that your setup is GPU-friendly and your
> >> problem size is appropriate.
> >> Best regards,
> >> Karli
> >> On 03/10/2018 03:38 AM, Satish Balay wrote:
> >>> I've updated configure so that --download-cusp gets the
> >>> correct/compatible cusp version - for cuda 7,8 vs 9
> >>> The changes are in branch balay/cuda-cusp-cleanup - and merged to next.
> >>> Satish
> >>> On Wed, 7 Mar 2018, Satish Balay wrote:
> >>>> --download-cusp gets hardly ever used so likely broken.
> >>>> It needs to be updated to somehow use the correct cusp version based
> >>>> on the cuda version thats being used.
> >>>> [and since we can't easily check for cusp compatibility - we should
> >>>> probably
> >>>> remove checkCUSPVersion() code]
> >>>> When using Cuda-9 - you can try options:
> >>>> --download-cusp=1 --download-cusp-commit=116b090
