[petsc-dev] [petsc-maint] Installing with CUDA on a cluster
Satish Balay
balay at mcs.anl.gov
Sat Mar 10 10:33:26 CST 2018
Karl,
[forwarding this discussion to petsc-dev]
* My fixes should alleviate some of the CUSP installation issues. I
don't know enough about CUSP interface wrt the useful features vs
other burderns - and if its good to drop it or not. [If needed - we
can add in more version dependencies in configure]
* Wrt CUDA - currently my test is with CUDA-7.5. I can try migrating a
couple of tests to CUDA-9.1 [on frog]. But what about older
releases? Any reason we should drop them? I.e any reason to up the
following values?
self.CUDAMinVersion = '5000' # Minimal cuda version is 5.0
self.CUSPMinVersion = '400' # Minimal cusp version is 0.4
We do change it for complex build [we don't have a test for this case]
if self.defaultScalarType.lower() == 'complex': self.CUDAMinVersion = '7050'
* Our test GUP is M2090 - with Compute capability (version) 2.0.
CUDA-7.5 works on it. CUDA-8 gives deprecated warnings. CUDA-9 does
not work? So what do we do for such old hardware? Do we keep
CUDA-7.5 is the minimum supported version for extended time? [At
some point we could switch to minimum version CUDA-8 - if we can get
rid of the warnings]
* BTW: Wrt --with-cuda-arch, I'm hoping we can get rid of it in favor
of CUDAFLAGS [with defaults similar to CFLAGS defaults] - but its
not clear if I can easily untangle the dependencies we have [wrt CPP
- and others]
Or can we get rid of this default alltogether [currently
-arch=sm_20] - and expect nvcc to have sane defaults? Then we can
probably eliminate all this complicated code. [If cuda-7.5 and higer
do this properly - we could use that as the minimum supported version?]
Satish
On Sat, 10 Mar 2018, Karl Rupp wrote:
> Hi all,
> a couple of notes here, particularly for Manuel:
> * CUSP is repeatedly causing such installation problems, hence we will soon
> drop it as a vector backend and instead only provide a native
> CUBLAS/CUSPARSE-based backend.
> * you can use this native CUDA backend already now. Just configure with only
> --with-cuda=1 --with-cuda-arch=sm_60 (sm_30 should also work and is compatible
> with Tesla K20 GPUs you may find on other clusters).
> * The multigrid preconditioner from CUSP is selected via
> -pc_type sa_cusp
> Make sure you also use -vec_type cusp -mat_type aijcusp
> If you don't need the multigrid preconditioner from CUSP, please
> just reconfigure and use the native CUDA-backend with -vec_type cuda -mat_type
> aijcusparse
> * Right now only one of {native CUDA, CUSP, ViennaCL} can be activated at
> configure time. This will be fixed later this month.
> If you're looking for a GPU-accelerated multigrid preconditioner: I just heard
> yesterday that NVIDIA's AMGX is now open source. I'll provide a wrapper within
> PETSc soon.
> As Matt already said: Don't expect much more than a modest speedup over your
> existing CPU-based code - provided that your setup is GPU-friendly and your
> problem size is appropriate.
> Best regards,
> Karli
> On 03/10/2018 03:38 AM, Satish Balay wrote:
> > I've updated configure so that --download-cusp gets the
> > correct/compatible cusp version - for cuda 7,8 vs 9
> > The changes are in branch balay/cuda-cusp-cleanup - and merged to next.
> > Satish
> > On Wed, 7 Mar 2018, Satish Balay wrote:
> >> --download-cusp gets hardly ever used so likely broken.
> >> It needs to be updated to somehow use the correct cusp version based
> >> on the cuda version thats being used.
> >> [and since we can't easily check for cusp compatibility - we should
> >> probably
> >> remove checkCUSPVersion() code]
> >> When using Cuda-9 - you can try options:
> >> --download-cusp=1 --download-cusp-commit=116b090
