[petsc-dev] Stale lib/petsc/conf/petscvariables interferes with prefix tests
Satish Balay
balay at mcs.anl.gov
Thu Mar 8 11:40:12 CST 2018
On Wed, 7 Mar 2018, Jed Brown wrote:
> If the most recently run configure is different from the prefix install
> you want to test, then incorrect variables get resolved. For example, I
> run
> make PETSC_DIR=/home/jed/usr/petsc-mpich-basic-prefix PETSC_ARCH="" test
> and lib/petsc/conf/petscvariables contains
> PETSC_ARCH=ompi-opt-singlelib
> PETSC_DIR=/home/jed/petsc
> include /home/jed/petsc/ompi-opt-singlelib/lib/petsc/conf/petscvariables
> which in my case defines variables like HYPRE_LIB which should be empty
> in the prefix install I'm trying to test.
> I think we normally don't notice because the correct petscvariables gets
> included later and supersedes anything defined here. Why isn't it spelled
> include $(PETSC_DIR)/$(PETSC_ARCH)/lib/petsc/conf/petscvariables
I guess the thought was: since we are hard-coding PETSC_ARCH and
PETSC_DIR values in this file - we should do the same for the include
directive.
If this change doesn't break the original intent [i.e there is a
default PETSC_ARCH/PETSC_DIR stored here - that gets used if user
doesn't set them explicitly in env or cmd] - I think you should go
ahead with it.
Satish
