[petsc-dev] plans for preconditioners for SeqSELL
Matthew Knepley
knepley at gmail.com
Sun Mar 4 18:00:12 CST 2018
On Sun, Mar 4, 2018 at 6:57 PM, Jed Brown <jed at jedbrown.org> wrote:
> "Zhang, Hong" <hongzhang at anl.gov> writes:
> > We have thought about subclassing long before. As Barry suggested, an
> > ideal solution is to make a base class (XAIJ ?) for AIJ, BAIJ, SBAIJ,
> > and SELL. The base class will have diagonal and off diagonal parts
> > without binding their storage format to CSR-type. This requires a lot
> > of efforts to refactor the current AIJ. But I think we should
> > eventually do it.
> It sounds like we're mixing the concerns of parallel decomposition (for
> which "Seq*" isn't relevant) with the sequential format as some CSR-like
> variant. And apart from a couple abstraction-breaking performance
> optimizations (that may not be necessary and could be done differently),
> they are nearly independent.
> Now there are some good reasons why we might want SeqAIJ to run inside a
> different parallel decomposition. MATIS is one such format. If we're
> serious about working with irregular problems, we'll eventually need a
> 2D sparse decomposition. We could get it from an existing package such
> as CombBLAS, but if we do preconditioners that depend on matrix format,
> we'll likely want it to work on some native format.
> Also, we need a better way to do small-size specialization. I
> personally like doing it via inline functions instead of macros and
> copy-pasta, though the XL compiler can be offensively negligent.
I have missed the larger point. What do you think should be done?
Matt
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180304/397787a4/attachment-0001.html>
