[petsc-dev] plans for preconditioners for SeqSELL
Stefano Zampini
stefano.zampini at gmail.com
Sun Mar 4 07:35:46 CST 2018
2018-03-03 9:52 GMT+03:00 Richard Tran Mills <rtmills at anl.gov>:
> Resurrecting a few weeks old thread:
> Stefano, did you get around to coding something up to do an automatic
> conversion to SeqAIJ for operations unsupported by SELL format?
No, I just added a faster conversion routine to SeqAIJ and support for
sequential MUMPS (which requires COO storage) and SUPERLU (the PETSc
interface already has a spot in the data structure for a copy of the
matrix) here
https://bitbucket.org/petsc/petsc/branch/stefano_zampini/feature-factor-sell
> I did some hacking the other day to try to get PCGAMG to use SELL inside
> the smoothers and this turns out to be way more complicated than I'd like
> and very bug prone (I haven't found all of mine, anyway). I think it may be
> preferable to be able to pass a SELL matrix to PCGAMG and have an internal
> conversion happen in the SELL matrix to AIJ format for doing the MatPtAP
> and LU solves. Support for this would certainly make it easier for users in
> a lot other cases as well, and might make the use of SELL much more likely.
> If no one has already done some work on this, I'll take a stab at it.
> --Richard
> On Mon, Feb 12, 2018 at 10:04 AM, Richard Tran Mills <rtmills at anl.gov>
> wrote:
>> On Mon, Feb 12, 2018 at 8:47 AM, Smith, Barry F. <bsmith at mcs.anl.gov>
>> wrote:
>>> > On Feb 12, 2018, at 10:25 AM, Stefano Zampini <
>>> stefano.zampini at gmail.com> wrote:
>>> > Barry,
>>> > for sure Amat,Pmat is the right approach; however, with complicated
>>> user codes, we are not always in control of having a different Jacobian
>>> matrix.
>>> > Since Mat*SELL does not currently support any preconditioning except
>>> PCSOR and PCJACOBI, we ask the user to put codes like
>>> > if (type is SELL)
>>> > create two matrices (and maybe modify the code in many other parts)
>>> > else
>>> > ok with the previous code
>>> I don't disagree with what you are saying and am not opposed to the
>>> proposed work.
>>> Perhaps we need to do a better job with making the mat,pmat approach
>>> simpler or better documented so more people use it naturally in their
>>> applications.
>> I wrote some code like that in some of the Jacobian/function routines in
>> PFLOTRAN to experiment with MATSELL, and it works, but looks and feels
>> pretty hacky. And if I wanted to support it for all of the different
>> systems that PFLOTRAN can model, then I'd have to reproduce that it in many
>> different Jacobian and function evaluation routines. I also don't like that
>> it makes it awkward to play with the many combinations of matrix types and
>> preconditioners that PETSc allows: The above pseudocode should really say
>> "if (type is SELL) and (preconditioner is not PCSOR or PCJACOBI)". I do
>> think that Amat,Pmat is a good approach in many situations, but it's easy
>> to construct scenarios in which it falls short.
>> In some situations, what I'd like to have happen is what Stefano is
>> talking about, with an automatic conversion to AIJ happening if SELL
>> doesn't support an operation. But, ideally, I think this sort of implicit
>> format conversion shouldn't be something hard-coded into the workings of
>> SELL. Instead, there should be some general mechanism by which PETSc
>> recognizes that a particular operation is unsupported for a given matrix
>> format, and then it can (optionally) copy/convert to a different matrix
>> type (probably default to AIJ, but it shouldn't have to be AIJ) that
>> supports the operation. This sort of implicit data rearrangement game may
>> actually become more important if future computer architectures strongly
>> prefer different data layouts different types of operations (though let's
>> not get ahead of ourselves).
>> --Richard
>>> Barry
>>> > Just my two cents.
>>> > 2018-02-12 19:10 GMT+03:00 Smith, Barry F. <bsmith at mcs.anl.gov>:
>>> > > On Feb 12, 2018, at 9:59 AM, Stefano Zampini <
>>> > > FYI, I just checked and MatSOR_*SELL does not use any vectorized
>>> instruction.
>>> > > Why just not converting to SeqAIJ, factor and then use the AIJ
>>> implementation for MatSolve for the moment?
>>> > Why not use the mat, pmat feature of the solvers to pass in both
>>> matrices and have the solvers handle using two formats simultaneously
>>> instead of burdening the MatSELL code with tons of special code for
>>> automatically converting to AIJ for solvers etc?
>>> > > 2018-02-12 18:06 GMT+03:00 Stefano Zampini <
>>> stefano.zampini at gmail.com>:
>>> > > 2018-02-12 17:36 GMT+03:00 Jed Brown <jed at jedbrown.org>:
>>> > > Karl Rupp <rupp at iue.tuwien.ac.at> writes:
>>> > > > Hi Stefano,
>>> > > >> Is there any plan to write code for native ILU/ICC etc for
>>> SeqSELL, at least to have BJACOBI in parallel?
>>> > > > (imho) ILU/ICC is a pain to do with SeqSELL. Point-Jacobi should be
>>> > > > possible, yes. SELL is really just tailored to MatMults and a pain
>>> for
>>> > > > anything that is not very similar to a MatMult...
>>> > > There is already MatSOR_*SELL. MatSolve_SeqSELL wouldn't be any
>>> harder.
>>> > > I think it would be acceptable to convert to SeqAIJ, factor, and
>>> convert
>>> > > the factors back to SELL.
>>> > > Yes, this was my idea. Today I have started coding something. I'll
>>> push the branch whenever I have anything working
>>> > > Stefano
>>> > > Stefano
>>> > Stefano
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180304/b4e6a190/attachment.html>
