[petsc-dev] plans for preconditioners for SeqSELL
    Richard Tran Mills
    rtmills at anl.gov
    Sat Mar  3 00:54:07 CST 2018
On Wed, Feb 14, 2018 at 6:15 PM, Jed Brown <jed at jedbrown.org> wrote:
> Richard Tran Mills <rtmills at anl.gov> writes:
> >> > I haven't experimented very thoroughly with it (hmm... should
> probably do
> >> > such experiments), but I believe that, once matrix rows become
> >> sufficiently
> >> > long, then SELL doesn't provide an advantage over AIJ.
> >> What is the performance model that explains why SELL doesn't benefit
> >> from long rows?  It's clear for large blocks where BAIJ can be compiled
> >> to vectorized loads and stores, but much less clear when AIJ is
> >> producing basically scalar code.
> > Hmm. I may be mistaken in my statements about long rows and AIJ -- I
> think
> > it might be the case that every matrix with long rows for which I've seen
> > the decent performance with AIJ was something that uses and benefits from
> > the Inode versions of the routines.
> Have you tested that Inodes are an improvement?  I've seen the opposite
> (by about 5%) on some recent Intel.
I have not tested this. I should give this a try and look into what is
going on, either way.
--Richard
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180302/c1aa84da/attachment.html>
