[petsc-dev] Handling pull requests in a better way
Patrick Sanan
patrick.sanan at gmail.com
Thu Mar 1 08:10:06 CST 2018
A simple way to proceed would be to advise submitters to submit their
"atomic" PRs in a valid order. If change B depends on change A, then submit
A first, wait until merged, and then submit B. This would have the nice
side effect of not overwhelming the integrators.
2018-03-01 15:04 GMT+01:00 Vaclav Hapla <vaclav.hapla at erdw.ethz.ch>:
> 1. 3. 2018 v 14:04, Patrick Sanan <patrick.sanan at gmail.com>:
> Maybe it would also help to add more explicit instructions to the wiki (
> https://bitbucket.org/petsc/petsc/wiki/Home#markdown-
> header-contributing-to-petsc) on how to construct a branch that is likely
> to get through the integration steps quickly.
> I'd suggest adding language about these (and volunteer to write it), even
> if some might be obvious:
> - Adding tests for whatever you submit
> - Testing with configurations other than the usual double/real/C setup
> (complex, single)
> - Making the PR as small/atomic as possible (can your PR be 2 or more
> separate PRs?)
> Yes, I think it's quite common that one would like to factor out one or
> more smaller bugfixes and/or improvements from a bigger PR. But some of
> them may depend on some others, and definitely the original big PR depends
> on all of them. Perhaps it would be nice if there is some documented way of
> specifying dependendencies between PRs to insure a proper order of merging
> (I think BitBucket has no such feature?).
> Thanks,
> Vaclav
> - Running through valgrind (using --download-mpich) before submitting
> 2018-03-01 12:33 GMT+01:00 Karl Rupp <rupp at iue.tuwien.ac.at>:
>> Dear PETSc folks,
>> I think we can do a better job when it comes to handling pull requests
>> (PRs). We have several PRs piling up, which after some time (imho) get
>> merged relatively carelessly instead of reaping the full benefits of a
>> thorough review.
>> In order to improve the integration of pull requests, I propose to
>> nominate a PR integrator, who is a-priori responsible for *all* incoming
>> PRs. The PR integrator is free to delegate a particular PR integration to
>> someone with the relevant domain-specific knowledge (e.g. Matt for
>> DMPlex-related things) by appropriate comments on Bitbucket. In case of
>> delays, the PR integrator is also responsible for issuing reminders over
>> time (like Barry has done in the past).
>> The idea is to make daily progress with the PRs. One integration step per
>> day (e.g. testing or merging to next) is presumably enough to handle the
>> load, whereas things get messy if we let things pile up. Automated testing
>> may help a bit in the future, but it doesn't release us from properly
>> reviewing the contributed code.
> Any objections to my PR integrator proposal? Any volunteers? ;-)
>> If nobody else wants to be the highly esteemed PR integrator, I can do
>> it. ;-)
>> Best regards,
>> Karli
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180301/a4e8887f/attachment-0001.html>
