[petsc-dev] GAMG and custom MatMults in smoothers
Matthew Knepley
knepley at gmail.com
Sat Jun 30 05:50:48 CDT 2018
On Fri, Jun 29, 2018 at 9:34 AM Vaclav Hapla <vaclav.hapla at erdw.ethz.ch>
wrote:
> > 22. 6. 2018 v 17:47, Smith, Barry F. <bsmith at mcs.anl.gov>:
> >> On Jun 22, 2018, at 5:43 AM, Pierre Jolivet <pierre.jolivet at enseeiht.fr>
> wrote:
> >> Hello,
> >> I’m solving a system using a MATSHELL and PCGAMG.
> >> The MPIAIJ Mat I’m giving to GAMG has a specific structure (inherited
> from the MATSHELL) I’d like to exploit during the solution phase when the
> smoother on the finest level is doing MatMults.
> >> Is there some way to:
> >> 1) decouple in -log_view the time spent in the MATSHELL MatMult and in
> the smoothers MatMult
> > You can register a new event and then inside your MATSHELL MatMult()
> call PetscLogEventBegin/End on your new event.
> > Note that the MatMult() like will still contain the time for your
> MatShell mult so you will need to subtract it off to get the time for your
> non-shell matmults.
> In PERMON, we sometimes have quite complicated hierarchy of wrapped
> matrices and want to measure MatMult{,Transpose,Add,TransposeAdd}
> separately for particular ones. Think e.g. of having additive MATCOMPOSITE
> wrapping multiplicative MATCOMPOSITE wrapping MATTRANSPOSE wrapping MATAIJ.
> You want to measure this MATAIJ instance's MatMult separately but you
> surely don't want to rewrite implementation of MatMult_Transpose or force
> yourself to use MATSHELL just to hang the events on MatMult*.
> We had a special wrapper type just adding some prefix to the events for
> the given object but this is not nice. What about adding a functionality to
> PetscLogEventBegin/End that would distinguish based on the first
> PetscObject's name or option prefix? Of course optionally not to break guys
> relying on current behavior - e.g. under something like -log_view_by_name.
> To me it's quite an elegant solution working for any PetscObject and any
> event.
As people have pointed out, this would not work well for Events. However,
this is exactly what stages are for.
Use separate stages for the different types of MatMult. I did this, for
example, when looking at performance
on different MG levels.
Matt
> I can do that if I get some upvotes.
> Vaclav
> >> 2) hardwire a specific MatMult implementation for the smoother on the
> finest level
> > In the latest release you do MatSetOperation() to override the normal
> matrix vector product with anything else you want.
> >> Thanks in advance,
> >> Pierre
> >> PS : here is what I have right now,
> >> MatMult 118 1.0 1.0740e+02 1.6 1.04e+13 1.6 1.7e+06
> 6.1e+05 0.0e+00 47100 90 98 0 47100 90 98 0 81953703
> >> PCSetUp 2 1.0 8.6513e+00 1.0 1.01e+09 1.7 2.6e+05
> 4.0e+05 1.8e+02 5 0 14 10 66 5 0 14 10 68 94598
> >> PCApply 14 1.0 8.0373e+01 1.1 9.06e+12 1.6 1.3e+06
> 6.0e+05 2.1e+01 45 87 72 78 8 45 87 72 78 8 95365211 // I’m guessing a
> lot of time here is being wasted in doing inefficient MatMults on the
> finest level but this is only speculation
> >> Same code with -pc_type none -ksp_max_it 13,
> >> MatMult 14 1.0 1.2936e+01 1.7 1.35e+12 1.6 2.0e+05
> 6.1e+05 0.0e+00 15100 78 93 0 15100 78 93 0 88202079
> >> The grid itself is rather simple (two levels, extremely aggressive
> coarsening),
> >> type is MULTIPLICATIVE, levels=2 cycles=v
> >> KSP Object: (mg_coarse_) 1024 MPI processes
> >> linear system matrix = precond matrix:
> >> Mat Object: 1024 MPI processes
> >> type: mpiaij
> >> rows=775, cols=775
> >> total: nonzeros=1793, allocated nonzeros=1793
> >> linear system matrix followed by preconditioner matrix:
> >> type: shell
> >> rows=1369307136, cols=1369307136
> >> type: mpiaij
> >> total: nonzeros=19896719360, allocated nonzeros=19896719360
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180630/a3677c94/attachment.html>
