[petsc-dev] testing on Titan
Richard Tran Mills
rtmills at anl.gov
Fri Jun 29 19:30:21 CDT 2018
Hi Mark,
I've got an OLCF account but don't have access to Titan. Would it be
helpful for me to apply to get on whatever allocation you are using so I
can poke around at this stuff? (If so, send me a message off list with
details of what I should apply for.)
Hopefully I could get on there faster than it took them to enable me on
Summit. I had volunteered to help with issues on Summit some time ago, but
it took so long for them to enable my account on there that I didn't matter
by then.
--Richard
On Fri, Jun 29, 2018 at 7:12 AM, Mark Adams <mfadams at lbl.gov> wrote:
> Thanks all, I knew this but its been a while since I've run on this file
> setup.
> On Fri, Jun 29, 2018 at 9:15 AM Seung-Hoe Ku <sku at pppl.gov> wrote:
>> Try copying files to scratch file system.
>> Home is not available when executive batch job. Probably interactive
>> she'll too.
>> On Fri, Jun 29, 2018 at 7:47 AM Mark Adams <mfadams at lbl.gov> wrote:
>>> I can not even run a job here. This is from an interactive shell:
>>> 64-pgi ex19-batch1:~/petsc/src/snes/examples/tutorials> make
>>> PETSC_DIR=/autofs/nccs-svm1_home1/adams/petsc PETSC_ARCH=arch-titan-dbg6
>>> cc -o ex19.o -c -fast -mp -I/autofs/nccs-svm1_home1/adams/petsc/include
>>> -I/autofs/nccs-svm1_home1/adams/petsc/arch-titan-dbg64-pgi/include
>>> -I/ccs/proj/env003/petscv3.9-dbg64-pgi/include `pwd`/ex19.c
>>> cc -fast -mp -o ex19 ex19.o -L/autofs/nccs-svm1_home1/
>>> adams/petsc/arch-titan-dbg64-pgi/lib -Wl,-rpath,/ccs/proj/env003/petscv3.9-dbg64-pgi/lib
>>> -L/ccs/proj/env003/petscv3.9-dbg64-pgi/lib -lpetsc -lHYPRE -lflapack
>>> -lfblas -lparmetis -lmetis -lstdc++ -ldl
>>> /autofs/nccs-svm1_home1/adams/petsc/arch-titan-dbg64-pgi/lib/libpetsc.a(dlimpl.o):
>>> In function `PetscDLOpen':
>>> /autofs/nccs-svm1_home1/adams/petsc/src/sys/dll/dlimpl.c:54: warning:
>>> Using 'dlopen' in statically linked applications requires at runtime the
>>> shared libraries from the glibc version used for linking
>>> /autofs/nccs-svm1_home1/adams/petsc/arch-titan-dbg64-pgi/lib/libpetsc.a(send.o):
>>> In function `PetscOpenSocket':
>>> /autofs/nccs-svm1_home1/adams/petsc/src/sys/classes/viewer/impls/socket/send.c:106:
>>> warning: Using 'gethostbyname' in statically linked applications requires
>>> at runtime the shared libraries from the glibc version used for linking
>>> adams at titan-batch1:~/petsc/src/snes/examples/tutorials> aprun -n 1
>>> ./ex19
>>> [NID 02258] 2018-06-29 07:45:09 Exec ./ex19 failed: chdir
>>> /autofs/nccs-svm1_home1/adams/petsc/src/snes/examples/tutorials No such
>>> file or directory
>>> Seung-Hoe runs here, maybe he can give me advice on what is wrong here.
>>> On Thu, Jun 28, 2018 at 7:53 PM Smith, Barry F. <bsmith at mcs.anl.gov>
>>> wrote:
>>>> 1) We need to get this PGI compiler into our regular testing. It
>>>> doesn't like some Fortran code the other compilers are ok with
>>>> 2) Mark, likely you just need to submit the examples manually to
>>>> run them. cd src/snes/examples/tutorials; make ex19 then use the batch
>>>> system to submit the example
>>>> Barry
>>>> > On Jun 28, 2018, at 5:35 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>>> > I am trying to run on Titan and I am having problems running the
>>>> tests. I get this output. It says it can not find a directory, but I do an
>>>> ls in after the error and you can see that it is there.
>>>> > I've attached the logs.
>>>> > Any ideas?
>>>> > Thanks,
>>>> > Mark
>>>> > adams at titan-login6:~/petsc> make PETSC_DIR=/ccs/proj/env003/petscv3.9-opt64-pgi
>>>> PETSC_ARCH="" test
>>>> > Running test examples to verify correct installation
>>>> > Using PETSC_DIR=/ccs/proj/env003/petscv3.9-opt64-pgi and PETSC_ARCH=
>>>> > *******************Error detected during compile or
>>>> link!*******************
>>>> > See http://www.mcs.anl.gov/petsc/documentation/faq.html
>>>> > /ccs/home/adams/petsc/src/snes/examples/tutorials ex19
>>>> > cc -o ex19.o -c -fast -mp -I/ccs/proj/env003/petscv3.9-opt64-pgi/include
>>>> -I/ccs/proj/env003/petscv3.9-opt64-pgi/include `pwd`/ex19.c
>>>> > cc -fast -mp -o ex19 ex19.o -L/ccs/proj/env003/petscv3.9-opt64-pgi/lib
>>>> -Wl,-rpath,/ccs/proj/env003/petscv3.9-opt64-pgi/lib
>>>> -L/ccs/proj/env003/petscv3.9-opt64-pgi/lib -lpetsc -lHYPRE -lflapack
>>>> > /ccs/proj/env003/petscv3.9-opt64-pgi/lib/libpetsc.a(dlimpl.o): In
>>>> > /autofs/nccs-svm1_home1/adams/petsc/src/sys/dll/dlimpl.c:53:
>>>> warning: Using 'dlopen' in statically linked applications requires at
>>>> > /ccs/proj/env003/petscv3.9-opt64-pgi/lib/libpetsc.a(send.o): In
>>>> > /autofs/nccs-svm1_home1/adams/petsc/src/sys/classes/viewer/impls/socket/send.c:101:
>>>> > /bin/rm -f ex19.o
>>>> > Possible error running C/C++ src/snes/examples/tutorials/ex19 with 1
>>>> MPI process
>>>> > [NID 18525] 2018-06-28 18:25:39 Exec ./ex19 failed: chdir
>>>> such file or directory
>>>> > Possible error running C/C++ src/snes/examples/tutorials/ex19 with 2
>>>> MPI processes
>>>> > [NID 18525] 2018-06-28 18:25:46 Exec ./ex19 failed: chdir
>>>> > 1,5c1
>>>> > < lid velocity = 0.0016, prandtl # = 1., grashof # = 1.
>>>> > < 0 SNES Function norm 0.0406612
>>>> > < 1 SNES Function norm 4.12227e-06
>>>> > < 2 SNES Function norm 6.098e-11
>>>> > < Number of SNES iterations = 2
>>>> > > [NID 18525] 2018-06-28 18:25:55 Exec ./ex19 failed: chdir
>>>> > Possible problem with ex19_hypre, diffs above
>>>> > /ccs/home/adams/petsc/src/snes/examples/tutorials ex5f
>>>> > ftn -c -fast -mp -I/ccs/proj/env003/petscv3.9-opt64-pgi/include
>>>> -I/ccs/proj/env003/petscv3.9-opt64-pgi/include -o ex5f.o ex5f.F90
>>>> > PGF90-S-0155-Could not resolve generic procedure dmdacreate2d
>>>> (ex5f.F90: 120)
>>>> > PGF90-S-0450-Argument number 2 to snesgetiterationnumber: kind
>>>> mismatch (ex5f.F90: 180)
>>>> > 0 inform, 0 warnings, 2 severes, 0 fatal for main
>>>> > PGF90-S-0155-Could not resolve generic procedure matsetvalueslocal
>>>> (ex5f.F90: 464)
>>>> (ex5f.F90: 477)
>>>> > 0 inform, 0 warnings, 2 severes, 0 fatal for formjacobianlocal
>>>> > gmake[3]: [ex5f.o] Error 2 (ignored)
>>>> > ftn -fast -mp -o ex5f ex5f.o -L/ccs/proj/env003/petscv3.9-opt64-pgi/lib
>>>> > /usr/bin/ld: cannot find ex5f.o: No such file or directory
>>>> > /usr/bin/sha1sum: ex5f: No such file or directory
>>>> > gmake[3]: [ex5f] Error 2 (ignored)
>>>> > /bin/rm -f ex5f.o
>>>> > Completed test examples
>>>> > adams at titan-login6:~/petsc> ll /autofs/nccs-svm1_home1/adams/
>>>> > total 1864
>>>> > -rw-rw-r-- 1 adams adams 11134 May 3 14:26 ex1.c
>>>> > drwxr-xr-x 3 adams adams 4096 May 3 14:26 ex10d
>>>> > -rw-rw-r-- 1 adams adams 92615 May 3 14:26 ex12.c
>>>> > -rw-r--r-- 1 adams adams 19324 Jun 21 17:59 ex13.c
>>>> > -rw-rw-r-- 1 adams adams 20550 May 3 14:26 ex14.c
>>>> > <make.log><configure.log>
>> Sent from Iphone
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180629/d04aee6a/attachment.html>
